I haven't had to do this yet , but wouldn't you know it, I need to do it now. I have read about the external alignments and am a little confused.
What I need to do is use an alignment I have for a part that gets about 5 operations. I am holding the part the same way as I did on the 1st op but have to check some points that are now there. I don't want to create a new alignment since it is being held the same way as before.
How would I save the alignment from the first operation so I can call it back up?
I hope this would work so I wouldn't have to manually hit the first alignment, but instead go straight to the DCC alignment.
All help would be appriciated
3.5MR2
