How do I know what workplane to use in pc dmis when dimensioning a true position feature. If I use a x workplane, the true position dimensions a y and z and diameter. If I use a y workplane, the true position dimensions a x and z and a diameter. If I use a z workplane, the true position dimensions a x and y and a diameter. When I use the y workplane, there is no red dimensions, however, when I use the x and z, there is red. What is the secret???
question on true position dimensions
If you are using DCC Features, workplane does not matter, you simply pick the 2 'minor' axis of the feature (the 2 with the smallest vector value). It is only for 'learned' features that you must be aware of the workplane since it wil use what you have active.sigpic
by john dHow do I know what workplane to use in pc dmis when dimensioning a true position feature. If I use a x workplane, the true position dimensions a y and...
03-03-2006, 02:52 PM -
by Big RedHow do I report the True Position using 3 Basic Dimensions?
I have 3 Basic Dimensions and I do not know how to report the True Position...-
03-22-2007, 06:40 PM -
by MsolitoIf you have a part ,that have a circle in a different workplane (in Xplus for example )and you use autocircle , do you need to change the workplane manually...
04-22-2009, 08:26 AM -
by RSNICKERWhy is it that I get different numbers when I report true position in the legacy dimensions than what I get in the new true position report and if so...
01-23-2009, 12:41 PM -
