Need a little help here.
I've setup an fixture and ran the program with a 1.5mm tip and all is well. There is a narrow long slot that they want profile points on and have to change to a .7 tip. All is calibrated but when I take a surface point it is 3mm off. I created a new probe file and still the same. I even went to a 1mm tip and still the same problem. If I switch back to the 1.5mm all is fine (within .05)
Any ideas (that would help)
