Demons again
  • Demons again
    When you mess with the alignment in a program and the message appears about hit "YES" it will change the features below and hit "NO" it will not. Is mine the only one that still does that no matter what the responce.
    Please help..... if there is a fix.
    SECSECSECSECFOOTBALL
    You hit no and it still changed stuff?
    I have had that happen on occasion. Closing the program and pc-dmis then restarting pc-dmis and opening the program again has always gotten it to behave as it should - but the program is still messed up from before.
    That is one of the reasons I like to have automatic file save turned off. If it happens and I haven't saved it, I can quit the program without saving. That way when I re-open I only have to fix what I did since my last ctrl+s. I also have made a habit of saving as a different name before I go messing with alignments.
      It has happened to me numerous times.
        I never have autosave turned on. Hit CTRL+S every couple of minutes and that is programmed in my body's involuntary mucsle memory.....
        Never, ever close a program if you've screwed it up and can't fix it. Quit, Quit, Quit. Then reopen your program and viola! it is back to where it was when you made the mistake.
        Contura Calypso 5.4
          Thanks for the reply..
          I did have auto turned save on.... So I will try it with it off.
            There is a setting within the SetUp Options (F5) that will affect the results of your response to this question.
            I keep this setting unchecked to allow "what if" scenarios.
            Lately, it occurs to me
            2017 R1 (Offline programming)
              John that option was turned on too.
              So I will try it with it off today.
              Thanks for the help and suggestions--let me know I have some friends in the PCDMIS world.
                One thing I always do. I save everytime before I start to work with alignments. I will add a number at the end. When I am done with a program I add the word Master at the end.
                • AuRules
                  PCDMIS closing
                  by AuRules
                  I have quit abit of programs wrote and have no problem with them (knock on wood) but I have 1 program that I can run, edit, start, stop but when I finished...
                  08-06-2009, 02:55 PM
                • Bearded_buddah
                  pc-dmis cmm autosave?
                  by Bearded_buddah
                  The situation - I keep coming into work to find out that part of a program "mysteriously" changed (ie work plane got changed from z+ to y- in...
                  01-29-2016, 01:21 AM
                • Wingman
                  Autosave On / Off
                  by Wingman
                  We use Autosave On. It has saved some time with code loss due to power outage (I know - buy an UPS). It has also saved code on crashes (I know - save,...
                  06-18-2007, 12:44 PM
                • fixin2
                  Missing Programs?
                  by fixin2
                  Currently running 4.2mr1. I started writing a program last night. I constantly hit ctrl+S to save after each feature I create. So last night before logging...
                  04-01-2008, 06:28 PM
                • DAN_M
                  Alignment keeps disappearing
                  by DAN_M
                  Very odd..
                  I have a program where ONE recall alignment keeps on disappearing.
                  I run the program and it gets to that line and...
                  07-07-2020, 10:35 AM
