Ooops
  • Ooops
    Hi Guys,
    I hope this makes sense, how do rotate the probe in the graphic display window?
    Some how I seem to have rotated the graphic probe in the display window by 90 degrees and I can’t figure out, how I did it. I know a little knowledge is a dangerous thing.
    Dave
    Have you switched the settings in the setup options (F5) ?
    Unless your machine axis match your cad axis things will not match up.
      No thats fine, I was tinkering with different menu options as you do and when I went back to the screen, the probe graphic on the screen had rotated round by 90 degrees.
      If I pull up an old program the probe on screen is shown out by 90 degrees as well.
        Sorted, It took a few days but I had changed a setting in the probe head orientation in the setup options
