I have been getting these errors while in edit mode. Now the errors are causing the programs lock and the serialization error will not allow program to open. It seems that these errors are happening on 2nd shift more that it is on 1st shift. The programs are stored on a server and the software is stored on the hard disk.
Errors while editing
I would definitely not run your programs from a server as this can/will cause you problems, i.e. if the server goes down mid program and your program cannot save, you will more than likely get the dreaded serialization error.
I store all my programs on the server but then have a copy of them all on the hard drive and run them from there, take it from me this will save you a lot of griefsigpic
Originally posted by jon_dav_uk View PostI would definitely not run your programs from a server as this can/will cause you problems, i.e. if the server goes down mid program and your program cannot save, you will more than likely get the dreaded serialization error.
PCDMIS 2012
Windows Office XP
You do not mention any version or OS you are running.
"A required resource.." message could be that you have not installed the MS hotfix for XPSP2. Or you could try running in "Best Performance Mode".
This assumes you are using Windows XP with SP2 installed.
Originally posted by SABarber View PostYou do not mention any version or OS you are running.
http://www.wilcoxassoc.com/Downloads/hotfix.htm
Originally posted by randy carr View PostI have been getting these errors while in edit mode. Now the errors are causing the programs lock and the serialization error will not allow program to open. It seems that these errors are happening on 2nd shift more that it is on 1st shift. The programs are stored on a server and the software is stored on the hard disk.sigpic
Originally posted by JamesMannes View PostYour 2nd shift needs administrative rights for their screen name. Your IT can set it up such that the 2nd shift has administrative rights but block everything they shouldn't touch via permissions.
The CMM department has agreed to move the programs to the hard drive with a backup on the server. My next worry is that I created setup sheets using Excel with photos and inserting the setup sheet into the program. These setup sheets are stored on the server along with the photos that are use in the excel setup sheet. From time to time I will experience an "applications error' while opening the program and have to close it before I can use it again. The setup sheet will be gone after that. I was wondering if everything concerning the software should be stored on the hard drive?
Originally posted by randy carr View PostThe CMM department has agreed to move the programs to the hard drive with a backup on the server. My next worry is that I created setup sheets using Excel with photos and inserting the setup sheet into the program. These setup sheets are stored on the server along with the photos that are use in the excel setup sheet. From time to time I will experience an "applications error' while opening the program and have to close it before I can use it again. The setup sheet will be gone after that. I was wondering if everything concerning the software should be stored on the hard drive?
We run 3 different CMMs this way.
We DID have a few problems like this for a short time and discovered a poor connection (loose and easily bummped junction). After reworking the physical connection the problems went away.Lately, it occurs to me
2017 R1 (Offline programming)
Why dont you guys create one folder per part number and then put the program(s), pictures, setup stuff, and anything related to that part number in that folder instead of in different places. It would make maintenance, moving, copying, backup, rev changes, etc... a lot easier.
by David KickIs it efficient to run PCDMIS residing on the local hard drive and the program files residing on a remote drive? I am trying to find the cause of a problem...
05-03-2007, 07:35 PM -
by chris_hHello all,
The IT department at my company want us to start working directly from the server so all of our programs would be created/saved on the...-
05-02-2017, 03:16 PM -
by AuRulesNeed a question or suggestion.
Currently we run 3 cmm's directly from a server. 99% of the time each cmm is running out of a different...-
07-22-2008, 08:10 AM -
by vader5094Hello all,
We are having issues with the PC-DMIS software taking way to long to save a file to our company server. The bigger the program...-
12-11-2007, 06:21 AM -
by justinb1022Hello everyone, Happy 4th of July!!
In the last week my PC-DMIS 4.1has been finishing a program and when its done it just exits on its...
07-02-2010, 11:38 AM -
