Hi all,
I have been having some trouble the past couple of weeks with my pcdmis not shutting down when I close out the program or to close and load another program. The programs run fine once they are loaded. Sometimes I have to close out of pcdmis and start back up, it will close and load about 2 times then it will lock up. Nothing has been changed on this computer for some time now. I have defraged and cleaned up the hard drive, I also cleaned out old datapage data. I have plenty of memory and space on my c: drive. It all seemed to start when I had an afternoon free and imported a cad model of the demo block. I don't use Cad but I see a lot of you do so I wanted to play with it. Now when it locks up I noticed at the bottom it always says "reading cad file from disk". What could I have done or what could I do to correct this problem. I have copied the cad file out of the pcdmis directory into another directory. This may not be the problem but it is the only thing I can think of that has changed.
TIA
Dale
TIA
Dale
