Half Angle
  • Half Angle
    How are you guys reporting the half angle of a cone.
    Create a generic cone and when calculating the angle use the measured cone's angle and divide it by two. For example, CON1.A/2
    PCDMIS 2012
    Windows Office XP
      I hadn't even thought of that.
      Thanks
      In the very early versions of PC DMIS there was a option for half angle if I remember correctly. I wounder what happened to it.
        Here is an example of what I do. I am guessing you figured it out already.
        ASSIGN/V2 = ABS(180-F1.A.MEAS)/2
        F2         =GENERIC/NONE,DEPENDENT,RECT,OUT,$
                    NOM/XYZ,0,0,0,$
                    MEAS/XYZ,0,0,0,$
                    NOM/IJK,0,0,1,$
                    MEAS/IJK,0,0,1,$
                    RADIUS/0,0,$
                    ANGLE/20,V2,$
                    DISTANCE/0,0
        DIM D10= LOCATION OF PLANE F2  UNITS=IN ,$
        GRAPH=OFF  TEXT=OFF  MULT=1.00  OUTPUT=BOTH
        AX  NOMINAL    +TOL     -TOL     MEAS    OUTTOL
        A   20.0000   0.5000   0.5000  20.1082   0.0000 -#-
        END OF DIMENSION D10
          I just go ahead and dimension the angle of the cone. They should be smart of enough to divide by 2 themselves
            HA! Not here...
            PCDMIS 2012
            Windows Office XP
              That is one thing to say, but they can respond with, "you should be smart enough to do your job and report dimensions as required by the print."
