I need help getting data from either my circles I measured or my profiles that I scanned. I have bores that are out of round and I need to know what the inscribed circle size will be to determine a gauge size. I'm not sure have to get the data I need. I'm currently running MM4 on an old Brown & Sharpe XCEL.
Help with MM4. . Need to inscribe a circle
Well, shucky darns! Mine doesn't even work anymore. I haven't even tried opening it in a few years.
If I remember correctly you've just got to construct it using an already measured circle. I just can't tell you the exact steps without looking at it. If your in ICON mode you should be able to see it in the "Construct" menu.sigpic
PCDMIS 2012
Windows Office XP
Okay, I got on another machine to figure it out.
In Icon mode go to "basic feature measurements", then go to the lower right icon "other options". Once you are there, you should see "MININS-MAXCIRC". Before doing this you have to have already measured your circle. Once you choose inscribed you will have to choose the circle you have already measured. It should be self explanatory from there. If not, let me know and I'll go through the motions on the other machine...sigpic
PCDMIS 2012
Windows Office XP
by jspicerI've got a question about a constructed circle theat I was hoping someone could help me with.
I've had to construct a circle from three partial...-
04-23-2008, 10:38 AM -
by AuRulesHave a circle in the zplane shaped like a football, would like to measure 2-1/4 circles on each side and build a circle from these hits. I did it a long...
11-30-2007, 09:00 AM -
by BIGWIG7Programming question
Say I have a 18.00'' diameter designated as a datum. However this particular diameter feature is not continuous, it...-
05-02-2018, 07:15 PM -
by GregSI was wondering if this was possible.
I checked 4 arcs on 30 degrees on 4 different probe angles. I want to construct a circle from those...-
06-16-2006, 09:29 AM -
by GeisterI used 3 different auto circles to take one 87 mm diameter due to fixture interference.
I thought I could just recall the 3 circles with construct...-
01-07-2010, 07:33 AM -
