Angles and polar angles
  • Angles and polar angles
    Hi guys, I have a question regarding how PC-DMIS calculates angles. How does the software "guess" as to which plane you wish to calculate the polar angle from and is it possible to override this "guess" somehow?
    I have a cylindrical part with holes on the OD and using the location->polar angle dimension I'm trying to get the angle with respect to the x-axis, having set my plane off of the yz face, but I believe it's trying to find the polar angle assuming an xz plane.
    Can anyone explain how I can get these angles right?
    This also occurs sometimes with concentricity of two circles not coming off the same plane if they're not measured with the same probe angle.
    Thanks,
    Jim
    Running 3.7MR2 with no hope of upgrades as our software license has expired
    active workplane
    It is based on your active workplane. Try switching around and you will get the hang of which workplane you need to be in for what you are trying to do. HTH
      So simple, yet so effective.
      Thanks a million, I honestly didn't really know what the purpose of the workplane was until just now. Good thing to know...
      -Jim
        workplanes are tres important
        Anytime you are trying to achieve a 2d dimension you need to be in the correct workplane. Otherwise your angle, distance, etc will be crazy. If you are new to CMMs, workplane is an idea you really need to understand. Many elements are 3d, like planes and cylinders, and workplane is not as important with them. But for lines, circles, etc, the wrong workplane will quickly equal a shiny skull.
          Or gray hair.
            Ya, I do mostly 3d distances and I guess by default have been working in the correct workplane all this time (~1.5 years and I have other responsibilities in addition to QC) just by setting it to whatever probe articulation I was working with. Now that I think about it, I've had some funky readings when it came to location distances and I went around that by using 3d distances instead of dimension locations. Learn something new everyday.
            Thanks guys.
              Thanks guys.
              Yes....we all learn something new every day...thats what makes this board so valuable!
              another thanks to all help here!
              sigpicDF
              The "NEW AND IMPROVED" Golden Rule!
              • TomCat
                how do i find this angle?
                by TomCat
                i am very new to pc dmis and cmms in general. just got thrown into this on monday. how would i go about finding this angle? i have 2 planes picked ( the...
                12-05-2018, 03:02 PM
              • Peter Warcholyk
                Angle?
                by Peter Warcholyk
                I've done an itterative alignment off of three tooling balls, and constructed my alignment.
                Next, I have measured three points on a boss...
                08-17-2006, 03:15 PM
              • CVJohn
                angle measurment
                by CVJohn
                I'm trying to measure the angles from 1 hole to another but I'm not getting any measurements. I've set up my XYZ orgins and using the location dimension...
                06-15-2009, 09:22 AM
              • globalstatus
                workplane question
                by globalstatus
                Hi guys... correct workplane is important only for 2d angles and 2d dimensions , not for 3d angles,dimension,angles or i am in wrong (talking about programming...
                05-05-2011, 08:02 AM
              • J. Lusk
                Beginer's probe angle question
                by J. Lusk
                When I change my probe head angle (i.e.:T1A0B0 to T1A90B180), I get a message that asks if I want to change my workplane Y-axis from plus to minus, vice-versa,...
                06-03-2008, 03:41 PM
