Feature construction help
  • Feature construction help
    V3.7MR3 CAD++
    Need some ideas.
    I've got a part with 2 small surfaces (co-planar) designated as my primary datum. I used an automeasure plane for each surface taking 8 hits on each. I want to construct a plane (Y axis base plane) from those hits and when I run it the plane shows off by 4mm in the Y axis. I've gotten it to work by pulling the points individually (cast points) then constructing my plane. I would really like to shorten it.
    Any ideas
    [CODE]PLN_X1 =AUTO/PLANE,SHOWALLPARAMS = NO,SHOWHITS = YES
    THEO/0,5.175,-7,0,1,0
    ACTL/0,5.175,-7,0,1,0
    TARG/0,5.175,-7,0,1,0
    MEAS/PLANE
    HIT/BASIC,1,5.175,-10,0,1,0,1,5.175,-10
    HIT/BASIC,-1,5.175,-10,0,1,0,-1,5.175,-10
    HIT/BASIC,-1,5.175,-8,0,1,0,-1,5.175,-8
    HIT/BASIC,1,5.175,-8,0,1,0,1,5.175,-8
    HIT/BASIC,1,5.175,-6,0,1,0,1,5.175,-6
    HIT/BASIC,-1,5.175,-6,0,1,0,-1,5.175,-6
    HIT/BASIC,-1,5.175,-4,0,1,0,-1,5.175,-4
    HIT/BASIC,1,5.175,-4,0,1,0,1,5.175,-4
    ENDMEAS/
    PLN_X2 =AUTO/PLANE,SHOWALLPARAMS = NO,SHOWHITS = YES
    THEO/43.18,5.175,-7,0,1,0
    ACTL/43.18,5.175,-7,0,1,0
    TARG/43.18,5.175,-7,0,1,0
    MEAS/PLANE
    HIT/BASIC,44.18,5.175,-10,0,1,0,44.18,5.175,-10
    HIT/BASIC,42.18,5.175,-10,0,1,0,42.18,5.175,-10
    HIT/BASIC,42.18,5.175,-8,0,1,0,42.18,5.175,-8
    HIT/BASIC,44.18,5.175,-8,0,1,0,44.18,5.175,-8
    HIT/BASIC,44.18,5.175,-6,0,1,0,44.18,5.175,-6
    HIT/BASIC,42.18,5.175,-6,0,1,0,42.18,5.175,-6
    HIT/BASIC,42.18,5.175,-4,0,1,0,42.18,5.175,-4
    HIT/BASIC,44.18,5.175,-4,0,1,0,44.18,5.175,-4
    ENDMEAS/
    PLN_X3 =FEAT/PLANE,RECT,OUTLINE
    CONSTR/PLANE,BF,PLN_X1.HIT[1..8],PLN_X2.HIT[1..8],,
    OUTLIER_REMOVAL/OFF,3
    FILTER/OFF,WAVELENGTH=0[CODE/]
    TIA
    Duane
    Contura Calypso 5.4
    Originally posted by dwade View Post
    V3.7MR3 CAD++
    Need some ideas.
    Any ideas
    [code]PLN_X1 =AUTO/PLANE,SHOWALLPARAMS = NO,SHOWHITS = YES
    MEAS/PLANE
    ENDMEAS/
    MEAS/PLANE
    ENDMEAS/
    TIA
    Duane
    Is there a reason you are not using "Midplane" to construct your DATUM plane from the two planes you measured?
      What W.C. said... That's what I was thinking...
      PCDMIS 2012
      Windows Office XP
        Was thinking with a bad case of "anusitus" yesterday and just couldn't see the trees for the forest was there....
        Thanks guys
        Contura Calypso 5.4
          So, this is RESOLVED ? ? ?
          PCDMIS 2012
          Windows Office XP
            Ok, I'm curious...
            If the goal is to create a new plane that contains all the points of the other two planes - like you would find in an interrupted plane - why would you use a midplane? All of the points from both planes lie on the same Y axis.
              Originally posted by cmmguy View Post
              Ok, I'm curious...
              J, if you are correct, I misunderstood. I thought he was essentially measuring two sides of a block to create a sort of "centerplane" DATUM. (Probably because I have several parts that are like that, combined with his saying the plane he created was off in Y.) If what you are suggesting is the case, then I would suggest he should not take two planes, but rather a number of vector points and then construct a single plane from them. Then if he needs a plane for each side he could construct those as well.
                Ok, I'm curious...
                This is what I want to do.
                Contura Calypso 5.4
                  What size tip are you using? A 4mm error almost sounds like comp error to me.
                    2mm styli.
                    When I wrote the program offline (ran offline too) all of my numbers looked good, but when I ran it on apart the numbers jumped on me.
                    If I construct the plane from either a midplane or individual points the part is in where it is supposed to be.
                    Contura Calypso 5.4
                      Are you measuring the points manually or DCC? I set up a quckie prog for this and if I change the order I take my points I have seen a lot of variation on my readings. I have been able to move my measured values +3mm/-1mm depending on the order I measure the points on my plane.
                        FYI. When you construct a plane from two planes it used the centroid of each plane rather than the raw hit data.
                          This should work:
                          If it doesnt then there is a serious problem with PCDMIS in allowing it or claiming it does.
                          Duane,
                          Try one more thing on this before giving up. Since planes need three points, maybe breakup the points to be like this...
                          CONSTR/PLANE,BF,PLN_X1.HIT[1..4],PLN_X1.HIT[5..8],PLN_X2.HIT[1..4],PLN_X2.HIT[5..8],,
                            All is done in DCC.
                            When I run the program and the plane is constructed using the method in the first post the triangle is positioned in front of the first plane measured and off plus 4mm in the Y axis, which is the direction the 2 planes are measured in.
                            Contura Calypso 5.4
                              If that matters, someone needs to answer some questions...
                              • #2#
                                Constructed Circle Problem
                                by #2#
                                Can anyone tell me why the Cir8 is way out in space?
                                CIR7       =AUTO/CIRCLE,SHOWALLPARAMS = NO,SHOWHITS = YES
                                            THEO/0,0,-0.3,0,0,1,0.313,0.2
                                05-30-2008, 11:43 AM
                              • Wingman
                                3.73 Still not right??
                                by Wingman
                                A while back I posted some weird issues with 3.73. I thought I had it solved by figuring out that 3.73 doesn't really like 3.72. Now it appears the...
                                07-26-2007, 10:39 AM
                              • mr500
                                Why Is My
                                by mr500
                                Why is my program stopping in the middle of the run. I have marked where it is stoping in the code. UGHHHHH
                                PLN2
                                08-18-2008, 03:11 PM
                              • #2#
                                Losing Alignment on Angle Change?
                                by #2#
                                Alright, here is my code. The first bit here is with A0B0. Just before the last move point it changes to A90B180.
                                 DATUM_B    =AUTO/CYLINDER,SHOWALLPARAMS
                                06-07-2007, 04:34 PM
                              • Underspec
                                Printing Variables!
                                by Underspec
                                I need to do some calculations and print them out from variables as dimensions or to the report. Never really messed with variables so any help will be...
                                08-09-2006, 01:51 PM
