MMC not working right.....
  • MMC not working right.....
    Please look at the screen shot. Why isn't MMC on the to datum feature holes being used to best fit the hole?
    If your RFS deviation in X and Y is greater than your tolerance, which it is, bonus will not be included in the calculation of your dev .
    sigpic 1.61803399Δ
      Are you saying that the modifiers on the datums are only applicable if the X and Y deviations fall within the RFS zone?
      Robert Horne
      Va.
        Makes no sense does it???
          Yes
          Of course it doesn't its PCDMIS
          Seriously though thats the way it worked in 3.7mr2.
          sigpic 1.61803399Δ
            No
            I just reread your question. I didnt get what you were asking. The modifiers on the datums are only applicable if the feature is in tolerance with the bonus included. If it is not then it reports the dev RFS.
            sigpic 1.61803399Δ
              Working as intended.
              Mr. Comment
              SCIROCCO-NT 13-20-10
                Well I just reread my original post and I guess i muffed that one Typing before thinking=bad.
                sigpic 1.61803399Δ
                  Working as inteded, eh? Try this experiment:
                  Report the feature linearly and look at just the X, Y and diameter. Then report the true position with x,y, the diameter and the bonus modifications. Be sure to use the datums with MMC. I'll bet you don't get the same X and Y deviations between the two reports.
                  • Rploughe
                    MMC of a Polygon
                    by Rploughe
                    I have a Hex called out as a datum and an ISR positioned below it. The ISR control frame calls out MMC for it and then calls out MMC for the Hex. How...
                    05-01-2014, 05:55 AM
                  • Tested
                    MMC on datum plane -A-
                    by Tested
                    Am I just missing something here.
                    Ø3.400 ±0.025
                    |TP|Ø0.08(M)|-A-(M)|-B-(M)|-C-(M)|
                    How do you know if MMC...
                    03-12-2010, 06:42 AM
                  • GEllsworth
                    MMC -vs- LMC
                    by GEllsworth
                    I had a discussion with an engineer that MMC should be used for hole diameters and LMC should be used for stud's or O/D parts. He didnt agree and said...
                    10-06-2009, 11:57 AM
                  • Duckhunter
                    MMC ISSUES
                    by Duckhunter
                    When PC-Dmis is calculating MMC why is it calculating from the top of the tolerance. I though that it should be applied from the 9.7 not the high limit...
                    05-12-2006, 05:15 PM
                  • metz317
                    Feature Frame Building
                    by metz317
                    Hello, I am trying to build a feature frame that essentially uses 4 datums. It's calling for the primary A MMC to B MMC, C secondary, and D tertiary....
                    06-27-2018, 04:50 PM
