circle sample Hit
  • circle sample Hit
    Hi Dears,
    I have a question with Ver 3.7 MR3, on Auto Circle, When I make a Circle and I want to move the sample hits, I right clock on sample hit and Click and Set " User Defined Hits" then I Drag the Hit , when I close the Window and re-open it, it is on Original hit klocations again....... What elese should I do ?
    thanx in advance
    You can always edit the start / end angles and spacer in the aotu circle dialog box and look at the changes on screen until they are the way you want them.
    James Temmen
      J Temmen, YOu are Right , my problem is, when I do Edit on screen and close the window ( F9 ), when I re-open that, I see my changes are not applied, indeed hits gone back to their original position !!!!!
        Can I retire Now?
        Tigershark, is it possible that you are not hitting the "create" button, but the "close" button instead? If you start an autofeature, and click close without having first clicked create, you have not created the feature. In the edit window there will be no code for the feature. When you click the autofeature icon again your theoretical information will still be there, but you will have lost dragged hits. If you do not want to measure the feature you can uncheck the "measure" box and still hit create. This will generate the code for the feature without actually trying to measure the feature. HTH
        P.S. #100
          opps
          I just realized you are asking about sample hits, not feature hits. I can't help you there. I don't check sheet metal and almost never use sample hits. I guess I was just too eager to reach my 100th post. LOL
          • Chally72
            AUTO CIRCLE Issues
            by Chally72
            I am using v 4.3 and I have encountered several problems with auto circles in the last week. These problems just cropped up out of nowhere and now will...
            11-03-2008, 11:19 AM
          • pniven
            Auto Feature no cad
            by pniven
            PHP Code:
            [HTML]Help File[/HTML]
            Without using CAD Data for an Auto Circle
            To generate the circle without the
            use of CAD data:
            Take three hits on
            05-20-2008, 10:34 AM
          • Darin Steiner
            Regenerate hits circle
            by Darin Steiner
            When I move hit targets in edit circle by moving them in the graphics window, then regenerate hits, it doesn't update the hits. It works fine on our other...
            03-01-2013, 09:05 AM
          • JR VILLA
            Autocirle hits
            by JR VILLA
            im having a problem moving my hits in the graphics view when I chose a hole the sample hits are there but I cant manipulate them if I change them in...
            10-02-2013, 03:00 PM
          • Wingman
            Auto Circle Sample Hits
            by Wingman
            All,
            I have need to move the sample hits for an Auto Measure Circle. Is this possible?
            I have half Circles and cannot use the point...
            10-24-2007, 08:36 AM
