Well I haven't seen this one before. It's a very small program, no CAD and doesn't do any thing fancy. Any one had it before or have an idea why I would get it?
Send the part program & steps to B&S tech support. Memory is being overwritten. Along with any other file (probe, alignment, registry settings, user dat). Also mention what report template is being used.
Buffer overruns are caused by security issues and/or coding issues. What version windows are you using? Are you on a network?
I'm running Windows XP Service Pack 2, and yes I am on a network. But only this one program has ever giving me this error and, I've built some more programs yesterday and they give me no problem. But if I go back to that one program and try to do anything to it I get the same error over and over.
You might try to make a new program name, copy and paste just the code in your new named program. Just a thought....
sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Country Rocks,But Bluegrass RULES!!!
buffer overrun detected, also no chance to get rid of it
hi together,
the same error like Mr. "tested" : buffer overrun detected, i work on Win XP SP2,
nvidia quadro FX 550, with two Benq FP93GX Monitors in Single view modus (no master desktop on TFT one and slave on two) in 2560 X 1024 Resolution. PCDMIS V4.2 MR1 installed 4 days ago no problems since then untÃl yesterday. All Hotfixies from Wilcox und Micrsoft are installed...
Small Prog with CAD file (import iges) about 200 Points with T aberration to look at in the graphik Window of PCDMIS. Program runs through (measuring mode) until i start to organize the T flags in the graphik window.
After 10 seconds to 40 seconds the error appears and pressing the OK button, PCDMIS is gone.
- its not just this Prog, happens in every old and new edit prog also
- reinstall of V4.2 MR1 didnt help
who can help, with hexagon metrology support in Wetzlar i discussed a couple of hours yesterday, no accurate answer form there yet
Hi franz-walt,
if it always happens by arranging the labels in the graphic-window
then my first attempt would be to update the driver for the graphiccard.
Today my co-worker was trying to access some information from within a program and somehow ended up with a Serialization Error; "An attempt was made...
I ran into this little gem this morning and couldn't clear it. I had to shut the controllers down and restart the system. Pressing Machine Start did...
