I would say that it is ok. The intent seems to ensure wall thickness is not violated.
They could have used the wall thickness and applied the profile once to the centerline.
I can not read the Thickness call out. Its .020? I see it .020 twice. Is it +/- .020 And if so what is the real thickness and what type of material and is it going to be a press fit into something? Is that area a lip of some sort. Would like to see more of print.
The wall is approximately .400 thick. The thickness tolerance is +/-.020.
Lately, it occurs to me
2017 R1 (Offline programming)
hello.run program PC-DIMIS CAD+ + 2010 MR3 and codes should not be cleared when the bag material thickness of an item and you do not have plugged.for...
hello I am new to the forum. how could I add material thickness compensation for example I have a part that gets nickel plated and we measure it before...
