true position strikes again
  • true position strikes again
    I have a callout for a t.p. of a hole of .8mm A,B,C MMC for all datums
    the hole is off 1.2 in the Z, .4 in the X , and .2 mm in the Y
    The T.P says a deviation of 3.2mm? How is this possible?
    Am I using this software right?
    First of all, please read this.
    http://www.pcdmisforum.com/showthread.php?t=3139
    Maybe post your program that measures the hole and the TP call.
    Jan.
      This is the actual formula:
      2*sqrt(x^2 + Y^2)
      "^2" is the term squared
      Example; 2*sqrt(.4^2 + .2^2) = .89443MM
      You are showing 3 deviations with a result of 3.2MM??????
      You only choose one feature to use the TP (assuming you have your datums set correctly) Datum 1, Datum 2 etc... are used to add positional tolerance if mmc is applied to that paticular datum.
      Robert Horne
      Va.
        This is because TP is deviation normal to the nominal axis of the feature. In other words, only two axis at one time. Three axis would be a spherical tolerances zone and I don't think that is what you have. post the print
        sigpic GDTPS - 0584
          UNLESS he has marked PERP TO CENTER LINE, it WILL give a 3-D TP value, including all axis deviations.
            But he should only report two for a cylindrical tolerance zone.
            Last edited by inspector212; 09-18-2007, 04:59 PM. Reason: added tolerance zone shape
            sigpic GDTPS - 0584
              true position
              By the way this 3.7 MR2
              What is the formula used to figure the standard deviation?
              Sorry about the thumbnail, I have security issues with the print.
              The coordinate is a simple plane,circle,circle with circle 1 the zero point.
                [ATTACH]1916[/ATTACH]
                Datums B and C are not features of size. So they should not have mmc applied to them. Have an engineer re evaluate the feature control frame.
                Robert Horne
                Va.
                  My issue seems to be I clicked all three datums giving me a sphere of tolerence.
                  The numbers seem alot more reasonable usiing just X,Y.
                  TIME for BEER!
                  I'm going to K.I.!
                    Exactly, good catch.
                    sigpic GDTPS - 0584
                      I'm going to K.I.!
                      Kings Island?
                      PCDMIS 2012
                      Windows Office XP
                        My Engineer say he sees nothing wrong.
                          P&G?
                            Then your engineer, like many others, has no idea how to use GD&T so he just populates the print with inacurate data.
                            Robert Horne
                            Va.
                              Now I have a print that calls out 2 true position FCF 's for a slot.
                              One tolerence for the width and a larger for the length.
                              Is this legal?
                              Is it needed, Since true position will give you a larger tolerence zone ?
                              • Bob Pierce
                                True position
                                by Bob Pierce
                                When dimensioning TP of a 2D hole to datums ABC, the hole being normal to Z, is the Z location being used in the calculation?
                                07-12-2007, 10:17 AM
                              • AuRules
                                Alignments/TP
                                by AuRules
                                99.9% of our blueprints uses +/- tolerance to control feature locations. Now after running these part for 40 years, the engineers wants to convert to...
                                07-16-2008, 02:29 PM
                              • MFCguy
                                Measured X, Y in TP
                                by MFCguy
                                X, Y locations appear to not be reporting correctly when using TP. Part is measuring darn near the nominal, when we know this isn't the case.
                                07-27-2010, 05:12 PM
                                TP Question
                                by *...*
                                Can someone tell me what the Max deviation in X & Y would be for a 2D true position callout of .007 RFS. This is a diameter tolerence zone
                                04-10-2008, 02:07 PM
                              • wacuna
                                True Position and Bonus tolerance
                                by wacuna
                                How does pcdmis calculate the bonus tolerance, when one of the datums has MMC applied to it?
                                12-07-2007, 04:30 PM
