For some reason, when I open a program, either my toolbars are missing a bunch of icons, or my CAD Model is missing. Sometimes both. Anyone know how to fix this? I have already renamed gbarstate and executebarsate. Even after I redo and save a new windows layout it still messes up. I have recently added a second monitor and a new NVidia video card. Only have 500 mb memory though. Think this is the problem?
toolbar issues
Tags: None
Why is it that my posts hardly ever get response? Just no answers out there???
Originally posted by jkb_mcg View PostFor some reason, when I open a program, either my toolbars are missing a bunch of icons, or my CAD Model is missing. Sometimes both. Anyone know how to fix this? I have already renamed gbarstate and executebarsate. Even after I redo and save a new windows layout it still messes up. I have recently added a second monitor and a new NVidia video card. Only have 500 mb memory though. Think this is the problem?
Hmm, sounds like pc-demons to me. I guess all I can offer is try going back to 1 monitor and see if the problem continues. If it stops, go back to two and see if it returns. That would indicate the problem has something to do with the dual monitor.
If you recall your saved windows layout does it pop back to the way you want it?
Originally posted by jkb_mcg View PostFor some reason, when I open a program, either my toolbars are missing a bunch of icons, or my CAD Model is missing. Sometimes both. Anyone know how to fix this? I have already renamed gbarstate and executebarsate. Even after I redo and save a new windows layout it still messes up. I have recently added a second monitor and a new NVidia video card. Only have 500 mb memory though. Think this is the problem?Robert Horne
Va.
Originally posted by robehor4 View PostI have the same video card and use dual monitors with now problem. I do however have 1 GB. So maybe???
I am running V3.7 MR3, same as you and I use 2 monitors without a problem.
SO, are you trying to SPAN both monitors with Pcdmis or are you putting it on 1 monitor and maybe the edit window on the second monitor? The main Pcdmis window I keep on the primary monitor and the most I will do is put the EDIT WINDOW on the second monitor.sigpic
Originally posted by jkb_mcg View PostFor some reason, when I open a program, either my toolbars are missing a bunch of icons, or my CAD Model is missing. Sometimes both. Anyone know how to fix this? I have already renamed gbarstate and executebarsate. Even after I redo and save a new windows layout it still messes up. I have recently added a second monitor and a new NVidia video card. Only have 500 mb memory though. Think this is the problem?sigpic
It's kind of funny ( not in your case), but that crap happened to me today. I opened the demon, selected my program, and "walloh", I had no toolbars or icons.Well, I will say this: When I initially set up my screen when we got the machine, there was ( and is) an icon that will store your preferred layout of the way you want your icons. Once you save them , no matter what happens, you can click the icon and your layout of the toolbars and such should reappear the way your originally laid them out. You may have to go to the "view" (toolbars) option to get to it, since you have no toolbars, and click toolbar which holds this icon. The toolbar you will want the machine to put back up is the " Window Layout" toolbar.Generally, the icon to the far right will be the (saved layout) icon. Get this toolbar up and click that icon (it should help). I cannot say this will help with the model problem, but I bet it will. The demon does strange things. This works for me on version 4.1, so I am not for sure if the older versions have this feature. IHTH
PatrickI don't feel tardy!sigpic
B&S "One" V4.2
Discovery D-12 V4.2
Originally posted by Matthew D. Hoedeman View PostI am running V3.7 MR3, same as you and I use 2 monitors without a problem.
2nd one, same as you.
Originally posted by 1CMM4ME View PostIt's kind of funny ( not in your case), but that crap happened to me today. I opened the demon, selected my program, and "walloh", I had no toolbars or icons.Well, I will say this: When I initially set up my screen when we got the machine, there was ( and is) an icon that will store your preferred layout of the way you want your icons. Once you save them , no matter what happens, you can click the icon and your layout of the toolbars and such should reappear the way your originally laid them out. You may have to go to the "view" (toolbars) option to get to it, since you have no toolbars, and click toolbar which holds this icon. The toolbar you will want the machine to put back up is the " Window Layout" toolbar.Generally, the icon to the far right will be the (saved layout) icon. Get this toolbar up and click that icon (it should help). I cannot say this will help with the model problem, but I bet it will. The demon does strange things. This works for me on version 4.1, so I am not for sure if the older versions have this feature. IHTH
Patrick
Originally posted by jkb_mcg View PostYes, I span them. pcdmis stays on the primary and the edit window on the
2nd one, same as you.sigpic
Originally posted by Matthew D. Hoedeman View PostThat's not exactly what I meant by span them, you CNA make a single window take up the entire area of BOTH monitors (at least, I can).
I had this happen to me today also. Lost all but one or two icons on most of my tool bars. Oddly enough I also use two monitors. I shut down PC-DMIS three times and my toolbars were still hosed. The only way I could get them back was to do a full shutdown then they were fine.Saving the world, one bad part at a time.
Originally posted by EHines View PostI had this happen to me today also. Lost all but one or two icons on most of my tool bars. Oddly enough I also use two monitors. I shut down PC-DMIS three times and my toolbars were still hosed. The only way I could get them back was to do a full shutdown then they were fine.
I guess when all else fails.....
by WScmmI have read some of the posts about dual monitors and our IT guys said he would look into setting me up w/ daul monitors. My question is can this become...
02-12-2009, 09:25 AM -
by DeWain HodgeI've been using dual monitors for years and finally have an issue. We got a second CMM from one of our plants that closed down and they sent it with...
09-14-2018, 10:34 AM -
by BSchwarkWhat vidio card was need to use a double monitor set-up? I tried it before and had some issues with my current set-up.
BS-
03-08-2006, 12:01 PM -
by Slug DawsonDoes anybody use their monitor in a vertical rotation? I prefer to use the monitor rotated so it is taller than wide. This way you can put the edit...
12-03-2009, 03:12 PM -
by JoBLOCKWell since I installed the nVidia card, I noticed that I do get less crashes, but I have a new symptom now, everything in pc-dmis is much slower, not...
07-10-2009, 10:07 AM -
