updated to 4.2mr1 but still ned to run 3.7mr3 until more time to learn 4.2 the problem is now the script used to run multi-execute in 3.7 will not work get error message "run time error 429 ActiveX component can't create object. called tech support they have not been able to help yet. any ideas?
multi-execute
This one is one that I have not dealt with yet. However it sounds like you cad is having issues working with the geometry. Again, this is just off of the wall. In my opinion, for whats it's worth. I would dbl check the res settings, etc. Basically just go down the line, the upgrade may have screwed with one setting and that is whats causing the error. From what I have dealt with, Active X is a video function and if it's creating the error (not knowing what #429 is), it may be conflicting with associating cad and the nominals with the cmm. Again, just an off of the wall guess.
Have a Great Saturday!
A.GoresigpicA.Gore
by mattfurtawI get error messages every once in awhile after the program runs and it's usually 10-20 windows. After clicking OK there are more. Doesn't do this all...
11-15-2010, 11:11 AM -
Does anyone have any idea how to make this go away? It only occures when I'm trying to do a save on a program with a large CAD file. The one I have loaded...
01-31-2008, 04:07 PM -
by DaddyBlutoI am trying to run a large program (probably too large > 32000 lines) written by our weekend guy. About 2/3 of the way through the program I get an...
04-22-2009, 02:23 PM -
by thefloydHello everyone, I am attempting to run a ballbar program I found in the ServiceUtils folder on my PC but I'm getting this error after running position...
02-24-2017, 01:39 AM -
by JeanoI am new to PC-DMIS. And I am having a problem. When I try to save I get an error of Serialization Error. Error:no error. From looking through the forum...
05-14-2009, 03:41 PM -
