What problems have you guys encountered making programs "read only" for protection purposes ?
Read Only Programs
Well, they can STILL be altered while open and executed and you get the annoying little error that Pcdmis can't save when you close and the stat count remains at what it was when you protected it, as well as the file name it wants to print too. Sure, the file name will index, but ONLY if the old reports are still there.sigpic
Bob, is this about storing them as read-only or using them as read only... There are two answer streams here and it makes a difference what you mean and what the answers mean.
Originally posted by cmmguy View PostBob, is this about storing them as read-only or using them as read only... There are two answer streams here and it makes a difference what you mean and what the answers mean.GLOBAL FX 12-15-10
3.7MR3, XP/SP2
Originally posted by BOB PARSONS View PostThey would be stored and used as read only unless your answer makes a really compelling reason to do it otherwise. We just have too many programs being changed w/out sufficient thought, causing crashing or other issues down the road!sigpic
I only asked to clarify your question and the answers. It seems READ-ONLY is one of the ways to protect them but it sure seems to limit the usefulness of some of the functions. There is another way and that is to make the folders secured by user to make them non-writable. This would also prevent unauthorized SAVE-AS functions so that altered copies cant be saved with new names and then reused later and also unapproved programs to be saved in the master directories.Last edited by cmmguy; 09-13-2007, 12:55 PM.
Originally posted by Matthew D. Hoedeman View PostTherein lies the BIGGEST (well, one of the biggest) problems with Pcdmis. Thereis NO WAY to keep the programs from being changed. If you can open it, you can change it, even if you can't save the change. We have all b1tched about this and NOTHING IS BEING DONE ABOUT IT!GLOBAL FX 12-15-10
3.7MR3, XP/SP2
Originally posted by cmmguy View PostThen matts and goodlucks answers cover it. I am wondering if jim means he loads them from the network as read only. With all the negative reactions about using the network.... maybe he can elaborate.
I only asked to clarify your question and the answers. It seems READ-ONLY is one of the ways to protect them but it sure seems to limit the usefulness of some of the functions. There is another way and that is to make the folders secured by user to make them non-writable. This would also prevent unauthorized SAVE-AS functions so that altered copies cant be saved with new names and then reused later and also unapproved programs to be saved in the master directories.sigpic
Originally posted by dwade View PostMake them run in "Operator" mode. Then you won't have to worry about it.GLOBAL FX 12-15-10
3.7MR3, XP/SP2
Originally posted by BOB PARSONS View PostUnfortunately, this option is not on the table for political and necessary editing reasons. This is mostly, though not always a nite-shift issue were trying to address.sigpic
Originally posted by JamesMannes View PostI open my programs from our network. I run the program. I quit out of the program. I go on to the next project/part (as of right now I have been running our "in process" parts for the last 2.5 months while our corporate people got thier heads out of their buttts and ponied up $$$ to fix one of my machines). Anyways I have been using the "in process" programs stored on our network with no problems. But of course I am using 4.2mr1 that may be why I am not having any problems?
by Robert RCan any one help me?
We are having a difficult time with inexperienced operators corrupting programs. Is it possible to save programs as...-
04-13-2007, 04:21 PM -
by LeeSpawHi there,
I have over 700 shopfloor programs and 3 CMM's.
The problem I have is the programs are always 'live'.
Any Tom,Dick...-
04-01-2008, 05:50 AM -
by PablopI seem to have some sort of file access problem. I have administrator rights on the PC-DMIS station, and I have read/write priviledges in the applicable...
06-05-2006, 03:04 PM -
by Paul Sarrachsaving problems .prg to server with programs during edits and saving reports IT thinks its our anti virus software Kapersky. When I save a program sometimes...
10-31-2014, 11:36 AM -
by why meI need help baaaaaaaaad
You see I am the only programmer here. I have been using Pcdmis for about a year. (I've been programming for over 13 years...
06-19-2006, 09:55 AM -
