I'm running DMIS 3.7MR1 on this particular machine. This is my problem with Auto Line - Every time I close out a program, the Edge Vector changes then next time I pull the program up. Then I am forced to search for all the Auto Line checks in the program and edit the vector. What the **** is going on here?
Auto Line
Well, I have never used auto-line, I always learn my lines (great for acting!) and I have never had one 'lose' it's way.
Also, for V3.7, MR3 is the best working version, upgrade if you can:
It might work better in the newer version.sigpic
I run V3.7MR3 and use auto lines a lot and do not have that problem either but I have found that I cannot use auto lines in an alignment. Throws things way out of whack....Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
I'm guessing it is a bug with mr1. I'd upgrade to mr3 if you can.
I know there was a bug with autoplanes in mr1 and mr2. It would change a plane in an existing program from a radial hit pattern to a square hit pattern or vice versa. It would change it to whatever the last one used was.
This is a known bug according to B&S, auto plane has some issues also, I seem to have more problems w/ FP3 control as opposed to older SHARPE-32 or WORLD CLASS controllers. My issues are not consistent, sometimes they work.
I second the suggestion for 3.7mr3 !GLOBAL FX 12-15-10
3.7MR3, XP/SP2
by JigneshI always use Auto vector ponits to make Auto line, and my literature of training does not show the method to make Auto line. Hexagon literature shows...
01-21-2016, 03:49 PM -
by QE161I just started looking at 4.3mr1 on my offline seat and have seen a problem with the lines in the auto feature section. It wants to use the start point...
01-06-2009, 08:22 AM -
by operator1Is it possible to create a line and/or plane using AUTO features? If so, how?
01-07-2008, 08:54 AM -
by SnaggyIs it just me or does anyone else find the auto line feature in 4.3 MR1 really really bloody annoying.
In the past I have always picked...-
02-20-2009, 05:31 AM -
