Curious if anyone out there is using your CMM for calibration. If so, can you list examples of what you calibrate? We are looking to use our new machine to help with calibrations.
CMM as Calibration Tool
All depends on tolerances of the gages and your CMM. Most likely fixture gaging would be the uses - like surface plate layout type of calibrations
It depends on a lot. What do you want to calibrate? What is the tolerance required for the gage?
I would NEVER use the CMM for calibrating gage blocks or ring gages. But I do use it to calibrate some of our fixtures that are used for part fit up. The tolerances on those are usually fairly liberal. (+/- .005 inch)When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by Underspec View PostI heard talk of gage blockssigpic
PCDMIS 2012
Windows Office XP
Well, it depends on what you use the gage blocks for doesn't it. I mean, if you use the gage blocks to calibrate something that only reads to two decimal places, a cmm would probably be good enough.
The only thing I've calibrated on ours is a 36 inch scale (overall length only).
They use it in drop testing units. They have to be dropped from 36 inches. We used to just have a steel bar but that wasn't good enough for an auditor. He said we needed something with markings so we could easily tell if someone cut off an inch or something - makes sense but wow is that being picky.
We use it a lot.
Any time the CMM is 10time better than the tolerance allowed I try to use the CMM.
The pwoers that be here continue to want me to layout fixture gauges to a gauge print; For the most part I refuse. Not only do the gauge print tolerances mean nothing to the actual part or part print. They also don't see the gauge the way the part will.
Originally posted by Goodluck View PostWell, it depends on what you use the gage blocks for doesn't it. I mean, if you use the gage blocks to calibrate something that only reads to two decimal places, a cmm would probably be good enough.
Originally posted by cmmguy View PostClassification of the blocks is more important than their use. Classification defines their possible use and that is what you calibrate to. I can't think of a any gage block standard - no matter how loose the tolerance - that would allow you to calibrate them on a cmm
Now, I KNOW that I am gonna get a ton of hate mail for this, BUT:
If you de-classify them, (no longer A, AA or AAA rated, or whatever they are) and state in your calibration paperwork that the acceptable tolerance for those gage blocks is, lets say, +/-0.0005", then you can do them with the CMM.
I AM NOT saying that this is acceptable to the original intent of the purpose of the gage blocks, BUT, if YOU can assign YOUR OWN acceptable limits, then yes, YOU can do it (waterboy)sigpic
.<internet bumper sticker goes here>
Originally posted by Matthew D. Hoedeman View PostWell, there are ways you CAN classify them and calibrate them on a CMM. First of all, it will depend on the actualy end use of the blocks.
[QUOTE=Matthew D. Hoedeman;84677]Well, there are ways you CAN classify them and calibrate them on a CMM. First of all, it will depend on the actualy end use of the blocks.
We used to do a lot of that in Saint Louis. When gage blocks exceeded their size tolerance, they were moved into less accurate sets. Those blocks ended up as feeler gages for shop parts. Not the cleanest system in the world but we were able to do it.Hilton Roberts
"Carpe Cerveza"
Originally posted by Underspec View PostCurious if anyone out there is using your CMM for calibration. If so, can you list examples of what you calibrate? We are looking to use our new machine to help with calibrations.Steven69
I calibrate attribute gages for metal stampings where applicable. Our tightest gage tolerance in ±.0002" on a small quantity of gages. Most of them are ±.0005" minimum.
Doing this I have greatly reduced the amount of manual data entry for gage calibration records. I shoot the CMM report to a .PDF file stored on the company server. If you start using your CMM for gage calibrations you can use that as a Continuous Improvement as well.Perry
B&S Mistral
3.207 Beta on XP
Older'n dirt
by rlafayOk got a question here.
I have a newly qualified CMM from Hexagon, an Excel in fact, and am thinking about the qualification procedure.
08-09-2008, 11:14 AM -
by DrEaMcMmhi,
i hav trimek CMM,the problem is that its measuring the 500mm gage block's nominal value as 500.012 and the actual or measured value is 500.022.can...-
12-06-2006, 12:04 PM -
by operator1I have a slight calibration issue. The CMM calibrates perfectly to the calibration probe, but does not calibrate to a boring gage set to 1.5743; it always...
08-14-2007, 08:57 AM -
Anyone here use a cmm to certify ring gage size. My company uses a million of these and the calibration cost is out of this world. We started looking...
12-08-2008, 09:30 AM -
by george fricki was wondering how your company calibrates master ring gages? we check our ring gages on our zeiss cmm's and use that data in our calibration files....
06-19-2006, 10:33 PM -
