Measuing cones using auto feature to find angle included on counter sink must be doing something wrong angle is way off. Or should I use points and construct cone? What is proper procedure using 3.7 mr3. any help appreciated.
measuring cones
Originally posted by kass_b View PostMeasuing cones using auto feature to find angle included on counter sink must be doing something wrong angle is way off. Or should I use points and construct cone? What is proper procedure using 3.7 mr3. any help appreciated.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
OK, lets take a look at this. I recently went through this very same problem (extruded cone counter-sink).
1) What are your machine specs and how much cone do you ahve to measure?
The one they wanted me to measure was so [email protected] small that the specs of the machine could give an answer that varied by almost 5 degrees (1.5mm of cone length, 52 degree cone).
2) How many levels and hits per level are you using? The more the better
3) I prefer manual (learned) cones over the auto feature. You can put 3 levels of hits with different numbers of hits per level. Seems to really help with cylinders, probaly helps with cones, too.sigpic
I have never had any luck with cones and always use circles =>cones
I use autocone often and I get it to work well, when there is a large enough cone to measure at least 3 levels and 7-15 hit per level. But as I said, it takes some tweaking to make sure all the hits are on the cone and not above or below it.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
by AlexAWhat are users experiences of cone accuracy, particularly the inlcuded angle.
Using microset moulding compound I'm reading 61deg 40mins,...-
04-14-2014, 09:36 AM -
by RNehfCould someone explain to me how to plug in the diameter when using the auto cone function. I am using version 3.7 mr3. There is only one box for the diameter...
11-11-2008, 09:06 AM -
by larsenqaI have not touched a CMM in years so please be gentle. Will I get an accurate/repeatable cone measurement if the cone is 0.120" deep has an angle...
04-30-2007, 09:27 AM -
by orioni have to measure and internal cone with an angle of 60° Please i know this is a stupid question but how do i measure the cone and report the angle
06-30-2010, 04:09 AM -
I have found that when measuring a cone with a measured feature the location of the measured cone is not accurate. I was using 4 points on 2 levels....
04-09-2018, 08:48 PM -
