I read on a previous thread that the way PCDMIS calculates a profile is incorrect. I could not find anything confirming or denying this. Does any know of a thread I can review or have comments for this?
Scanning results
Originally posted by robehor4 View PostI read on a previous thread that the way PCDMIS calculates a profile is incorrect. I could not find anything confirming or denying this. Does any know of a thread I can review or have comments for this?sigpic
IF you are scanning WITH cad data, then Pcdmis uses the cad nominals and cad vectors for all touches. The results will be reasonably close (on the order of microns) unless your form is really whacked (on the order of 15 degrees off or more)
IF you are scanning anything with a touch-trigger-probe (the only kind I have so the only kind I know for sure), then unless you are using SURFACE POINTS with a minimum of 3 sample hits per hit, then the comp for the probe radius will NOT be correct, it will only be along 2 axis, not 3. This is fine if you are scanning a 2-D profile. However, if you are scanning a 3-D surface, then the probe comp will not be correct. If you are scanning 'up/down' in the 'x-axis', you will get no probe comp in the 'y-axis' direction and you could easily be off a BUNCH. For this reason, when doing a NON-CAD scan of a 3-D surface for reverse engineering, COMP=OFF is your best bet.
IF you are talking about the PROFILE dimension itself, it will depnd on what version you have. It WILL be correct, but you may need help in understanding what it is telling you. In some versions it takes teh highest deviation and doubles that value (treating it like true-pos) and in some versions it takes the highest to lowest and reports that value. If you report each point as a point and not part of a scan or set and use the T axis, that will always tell you the correct value (use 1/2 of the profile tolerance for the +/- value ie profile tol of 1.0mm = +/-0.5mm).sigpic
Thanks for your info. I wish I could find that thread again, since I use CAD for everything here and have compared results to a profrile tracer Im confident with my results. Since I didnt here any negative responses from you guys I will continue with my current process. Thanks again.Robert Horne
Va.
See this post:
http://www.pcdmisforum.com/showthrea...hlight=profile
Yes, I remain strongly opinianated against the way PC-DMIS reports profile using the 4.x XactMeasure profile dimension. It is dead WRONG. But Wilcox disagrees and that is OK because by using the MIN/MAX you can get to the correct answer. So as long as you know what the problem is, it is easy to get to the correct answer.
Jan.Last edited by Jan d.; 09-12-2007, 10:53 AM.***************************
Jan.
Jan.Robert Horne
Va.
by T-StarkI have never had to get a 3 dimensional profile before on my CMM. Someone please help. I have been given a pretty wicked 3D part that calls for a profile...
02-04-2013, 05:08 PM -
by KellyTTIHelp! We were running version 3.7 and 2011 for the longest time. I am still new to this (2 years), but an quite comfortable as programming is what I...
05-30-2014, 08:32 AM -
I need to reverse engineering a rectangular area at X=.1 by Z=.1 hard increments for the whole area. Anyone know the best scan for this?
03-27-2008, 07:23 AM -
by Benedictj1LSP-S2 scanning over multiple surfaces. I keep getting "tail" of hits floating over corners. I have not been able to get rid of them.
11-19-2019, 12:41 PM -
by enviroHi All, I am trying to scan a blade profile to export as IGES to create a reversed engineerd part.
I was told somewhere up the line that PATCH...-
02-25-2009, 03:16 PM -
