Iterative Alignment using 3 holes ?
  • Iterative Alignment using 3 holes ?
    I am trying to do an iterative alignment using 3 holes and am having trouble getting the cad file to merge with the part. I have done this before but am a bit on the rusty side. Any tips are appreciated. I am starting my program with dcc mode turned on. I am using auto feature dcc circle for all 3 holes. After I measure the holes I am going into iterative alignment leveling to the 3 holes
    aligning to 2 of the holes and selecting origin for 1 of the holes. Then I select cad=part. It asks me if I want to re measure the alignment features and I tell it yes. It re- runs the circles but the cad and part do not merge. Not sure what I am doing wrong. Also what should I set the point tolerance to in the iterative alignment box. I forget what point tolerance does. Can ayone remind me ? I rarely use iterative alignments but would like to brush up on them.
    Thanks
    Erik
    Thanks
    Erik
    You absolutly HAVE to use a minimum of 3 surface sample hits for holes when doing an iterative alignment.
      I am using 3 sample hits.
        I can't remember who created this doc but it wasn't me so I don't want any credit for it. That being said I think you'll find it useful.ITERATIVE_ALIGNMENT_GUIDE[1].zip
        sigpic 1.61803399Δ
          Is ther a tutorial available for doing iterative alignments? I used to have one from PCDMIS Class but cant find it and we have no tech support here unfortunately. I am trying to get brushed up for a job interview at a plastics mfr. They may quiz me and would like to be up to speed. Thanks for the help.
            Thanks so much !!
              #1) Do not start your program in DCC mode, leave it in manual mode
              #2) pick the featues from the cad model and create them (do NOT measure them)
              #3) Do the iterative alignment
              #4) Do not do CAD=PART (will not hurt, but don't do it unless you are an expert, the cad=part is NOT on the iterative alignment screen)
              #5) mark and execute
              Set your tolerances HIGH on the iterative alignment screen for the manual, then when you do it all again in DCC mode, tighten them up.
              also, see this:
              http://cmmprogrammer.19.forumer.com/viewtopic.php?t=434
                Thanks again !!
                  Originally posted by slesholdofthreep View Post
                  I can't remember who created this doc but it wasn't me so I don't want any credit for it. That being said I think you'll find it useful.[ATTACH]1858[/ATTACH]
                  Winston
                    sigpic 1.61803399Δ
