Hot Key shortcuts
  • Hot Key shortcuts
    Ladies and Gentlemen,
    I am doing a lot of offline programming (with cad thank goodness ;o). Im sure you'll appreciate the need for seeing the path lines and subsequent collision detection. I wanted to create a hot key for this (shift & P).
    Right, I have gone into:
    View
    Toolbars
    Customise
    Keyboard
    View
    Path Lines
    I have then entered "Shift & P" in the new shortcut field, assigned it, applied it and ok'd it.
    Thi shortcut (hotkey) appears next to the Path lines function on the drop down menu but when I press shift & p. Nothing happens. What am I missing????????
    Best
    TIA
    F
    Recently jumped from 3.5 Mr 2 CAD
    to 2012 CAD++
    It seems to me that none of the factory hot keys use SHIFT+ an alphanumeric character. Try a different combo.
    sigpic 1.61803399Δ
      Try alt-p. That worked for me.
        Path lines
        I am not able to apply this. What am I missing?
        Robert Horne
        Va.
          Cheers fellas, I'll give it a bash.
          Watch this space!
          ITS WORKING!
          Alt works like a dream.
          Doesnt like shift for some reason - thats odd.
          Any way
          Thanks as always guys.
          to 2012 CAD++
            Watch this space!
            ITS WORKING!
            Any way
            Shift probably doesn't work because how would the computer know if you wanted to type "P" or use the shortcut?
              Do you mean you when you apply this it doesn't work or that the apply button is grayed out?
              sigpic 1.61803399Δ
                Correct the apply button is greyed out.
                Robert Horne
                Va.
                  Works with 3.7MR2 but not with 4.1 that sucks
                  Robert Horne
                  Va.
                    I run 4.1 and custom hotkeys work for me
                    sigpic 1.61803399Δ
                      Never mind it works with both???
                      Thanks for the help
                      Robert Horne
                      Va.
                        Hmm, could that be another difference between pro, cad and cad++?
                        Could it be that the combination you chose is already assigned to something else?
                          iT SHOULD COME UP WITH A WARNING, BUT THAT'S KIND OF WHAT i THOUGHT MYSELF
                            Here is a list of hotkeys.
                              I got it now. Thanks for the help
                              Robert Horne
                              Va.
