How do I get a series of text boxes to appear at only the end of the report - on the Last Page?
Report Help
I think one thing you could do is use a footer template and modify that to contain the text boxes and the information you want to display. That should appear on the very last page if you only have one section.
Here's what I would do (using 4.2)- Access label template editor.
- Open an existing footer templates or create a new label temple as your footer. Modify it to contain your txt boxes.
- Then in the Report Template editor, access your report template and right-click on the TextReportObject to get its properties, and access the Rule Tree.
- There, expand Miscellaneous and for Bottom of Last Page in Section add a rule to have it use the footer label template you defined.
Jared Hess - Techwriter @ WAI
Whatever you add to the report template you are using will affect all pages. If you want it to affect only the last page I would use comments.I used to be high on life but I built up a tolerance.
Another suggestion: How about adding another Section to your report? Open your existing template and go to the bottom of the view. Right click on the Tab (probably called TheView0) and insert a new section. In that section, add your footer label. This was, these templates will ALWAYS show up at the back of your report.
I've created a sample footer label template file (.lbl) and placed in on the WAI website if anyone is interested.Jared Hess - Techwriter @ WAI
by dadracer71Hi all,
I am trying to DD Pgwe numbers to my report, only I can't find out which report I a using. so I am making the change acroos the board....-
Channel: Tips & Tricks
02-21-2014, 03:42 PM -
by Department SCad and text report is what I use 99% of the time. I report a lot of points in one axis and sometimes PC-DMIS puts 4 points on a report page and on another...
03-03-2017, 11:57 AM -
by Steven69I am doing a small amount of modifying on my text reports after watching the tutorials. Does anyone have a formula that will allow me to add the page...
07-22-2008, 11:13 PM -
by ClyonsAll of our reports list the page numbers as 1/1, 2/1, 3/1, etc. and then the last page is 1/1 again. This is on 2012 and 2013 versions of PC-DMIS, text...
10-02-2014, 09:50 AM -
by Big JohnHallo,
Question: How kan I set up my report printing so that the page numbers are also exported. In PC_Dmis the page numbers are visible,...-
04-03-2012, 12:45 PM -
