I'm wanting to know how to use the looping command. I'm trying to use it on a gauge R&R to make it go quicker. Any advice would help out a lot.
PC DMIS 4.2
Iota 2204
I only have 3 hits for the Gauge R&R and those are the dimensions I'm trying to loop. I do how ever need to record each dimension witch I usually do that by writing it down & then inputting it into a Gauge R&R results excel sheet. I was planning on hitting hold run to record the data & load parts.
If you are not using Datapage I'd recommend writing them to a text file, saves the pausing to write stuff down and can be imported into Excel. That is what I do
Insert | Looping
Before the 1st feature that is being measured.
Insert | End Loop
After the last feature that is being measured.
In v3.7 I have seen issues with move points inside looping. I'm not sure if it still exists in v4.2. You can go into the Insert | Loop menu and press F1 to get more detailed help.
You can also try the MultiExecute Wizard by right clicking the toolbar above and enabling the Wizards.
Hello all. My company just got a big job where we are running 8 parts on the table with each having its own fixture during the program. Is there any...
This may be the wrong forum for this question but I'm gonna start here... I did try a search but all the results I got were really old so I thought I'd...
