PCDMIN dual install question
The best advise to follow is Matt's for setting up and running multiple versions of the DEMON.
http://cmmprogrammer.19.forumer.com/viewtopic.php?t=101
I have 3 that can run and if you follow his advise the only path you really have to change is the probe file and your program file directory. I jump from V3.7MR3 to V4.2 quite a bit as one of our siter plants runs V4.2 and I help out when needed and this is all I change to bounce from one version to the other.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
dwade,
Yeah got that and many others saved to favorites. Followed it and it worked like a charm. I'm just tring to fool proof it cause when you set the search path you have to select the correct folder AND hit apply. It would be nice to dbl click an icon prior to opening a different version. I just know my backups are going to be useful.
I would love to see this fixed in a future release. Once you set the path for that specific version it SHOULD stay there.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Well... usually not so obviously.
You wanted to switch paths with a double-click of an Icon.. right? Well that is what William is describing how to do.
Is this what you wanted?
if so, do you not get the jist of what he is describing to do?
Yes this is what I want to do.
I guess I should have made my skill set abit more clear, I am only a fledgling computer geek
What william is explaining is how to go into the registry of the computer and find the paths entries and saying that you can export these out.
Do this after each set of paths are configured in each version of PCDMIS.
Then to switch the paths, you double click on the icon of the exported registry settings - this resets the registry to the settings that were exported.
If this seems over your head, then I might recommend that you dont do it. Messing around in your registry, although not difficult, can be a computer trashing experience.
take a look here: ftp://ftp.wilcoxassoc.com/Werner/PCD...ionStarter.zip
It does a great job if you have multiple PCDMIS-versions installed,
because you can set different search paths (for probes and partprograms)
for each version
HTH
Today I thought I would install 4.2MR1 on my offline station and have a "play" to see if it is worth changing over and see what, if any the "enhancements" are like. I am also having problems with the dreaded serialization error quite frequently and would be interested to see if this version has overcame this.
The first thing I noticed was the default directory for installation had changed. Previously always C:\PCDMISW, it is now C:\Program Files\WAI\PC-DMIS V42.
As this is a new directory, I chose to install the software into this folder. (Matt's recommendation is to copy your existing directory, rename it to the new directory then install over the top. I did not do this as I figured when working offline, I do not need all the comp files etc)
I then set-up new areas for programs / probes / CAD Data etc
C:\Data\Common\PC Dmis V4-2MR1\Programs
C:\Data\Common\PC Dmis V4-2MR1\Probes
C:\Data\Common\PC Dmis V4-2MR1\CAD Data
Started V4.2MR1, set all of the default search paths to the above file directories and exited the software.
Started V3.7MR3 and all the default paths have changed to the above also
Had a quick look in the windoze registry although I do no know a lot about what goes on in there and I could only find one entry for PC Dmis, i.e. it looks as though both versions are now reading this same reg entry.
Can anyone spot if I have made an obvious error or offer any advice
Cheers
Jon
PS - I was given full administrative priveleges by the IT department for the install and also started the demon the first time with these priveleges.sigpic
There are TWO areas in the registry that get humped on.
One is the machine and one is the user.
Both under Software|WAI
I think that you can setup two different users on the PC and each one will have its own settings. You could have a 3.7 user and 4.X user. I am beginnin to think this might be viable for all these intallations.
I use 3.7mr3 normaly and the search path for probes are as follows C:\PCDMISW37MR3\ProbeV37mr3\
The problem acurres when i change to 4.3mr1 and...-
02-10-2009, 10:34 AM -
by cmmmikeI have a question on setting the search path. When I set the search path in 3.7 it also changed it in my 3.5 version. They are both on different directories...
07-14-2006, 10:54 AM -
by doo_hickyWith the different version downloads that I have got, I have labeled the different folders WAI, WAI1, and WAI2. When I open a different version, say...
07-01-2008, 09:42 AM -
Hi Gang>
Have to keep two versions for the time being on CMM 3.7MR4 and 4.2MR1. Made seperate probe folders to keep 4.2 from updating the 3.7...-
03-30-2008, 09:43 AM -
by MrCommentI was curious if anyone knows how to set the probe file directory search path via the code?
I want to have the program change the Edit>Preferences>Set...-
09-12-2006, 02:22 PM -
