For the tp20 & tp200 your only control over trigger force is the type of module you use. For the tp20 you can get low, standard, medium, or extended force. To the best of my knowledge for the tp200 there is only standard force and low force. HTH
OK, Thanks guys. Guess I am not as dumb as I thought ( nobody's that dumb). What do the values under the Opt. Probe tab in Parameter Settings have to do with.
I'm using a MIP probe head and was wondering if longer tips or those with extensions require a higher trigger force? If so, is there a chart available...
