I have this hole that is dimensioned from the flanges around it. It shows that the flanges are 0.400 from the tangent of the hole.(see bp) I was thinking of creating some points on the flange offsetting them 0.400, then create a plane from these points, then measure the hole with a cylinder then try to construct a point at the intersection of the plane and the cylinder. I wonder if this is going to work, anyone done this before?
How would you measure this hole location?
For flange 1: I would measure a plane (construct from points) on the flange and then do a 3D distance from the circle to the plane (subtract radius).
For flange 2: the same, except that flange looks curved. If your tolerance is great enough then the above method will probably be ok. (maybe it isn't curved, looks close enough to flat that it is probably ok)Lately, it occurs to me
2017 R1 (Offline programming)
Originally posted by John Riggins View PostFor flange 1: I would measure a plane (construct from points) on the flange and then do a 3D distance from the circle to the plane (subtract radius).
What you want to do is be sure that you are in the correct view plane (if looking down from above it would be +Z), open dimension tab "distance" choose the circle and then choose the plane, choose subtract radius, choose "feature to feature". This will give you a distance that is parallel and/or perpendicular to your features.sigpic
How I would measure them, since I see NO datums called out, I ouwld measure all of the features back to the ABC datums, using the CAD data. I would call those 'build dimensions', dimension put on the print so that a cad model can be created.sigpic
Originally posted by JamesMannes View PostUsing 3D will give you a value that includes all three axis'.
I would use pre-hits when taking that circle.sigpicSummer Time. Gotta Love it!
Originally posted by Paul Sarrach View PostOkay, I am lost. 3 axis's? I believe a Plane to a point ( Centroid ) would give you a perpendicular distance ( one axis ). Am I missing something here?
Yes, No, maybe so?sigpic
Originally posted by JamesMannes View PostAs far as I understand the 3D distance feature, it is workplane independant, and will report a value that is "as the crow flies". That is using a 3D line from centroid to centroid.
Yes, No, maybe so?sigpicSummer Time. Gotta Love it!
Originally posted by Paul Sarrach View PostA crow does not fly in a strait line, but the shortest distance to any two things is. Which is only one axis. Yes/No? Then I have a whole lot of reports that are bogus.sigpic
Originally posted by george frick View Postsomething to think about: are the flanges defining the location of the hole
or is the hole defining location of the flanges? .40=2 pl decimal- plenty of
tolerance either way. what do you think?sigpicSummer Time. Gotta Love it!
Yes, No, maybe so?Bill Jarrells
Yes, No, maybe so?Originally posted by Wingman View Post3D distance from a PLANE is NORMAL to the Plane.
sqrt(Xdiff^2 + Ydiff^2 + Zdiff^2)sigpic
by greenergrassHi all, New here.I appreciate any help you can give. My question : I am using version 3.5 cad++. How can I fiqure out the vector of a hole that is on...
02-11-2008, 10:38 AM -
by Big Red1) I have a plane that is parallel to "Z" axis. I call this my "Top plane".
2) In the center of this plane is a 2"...-
01-23-2007, 07:40 PM -
by Big RedWhen 'Constructing' a Circle, what is the difference between "Projection" and "Intersect"?
Usually, my true position...-
04-07-2007, 02:15 PM -
by jeremyray25I need some advice on checking a threaded hole that is on a 4 degree angle. Currently, I am measuring the 4 degree plane and then placing a threaded...
12-12-2008, 05:06 PM -
by dirkoSay you had a pipe with very thin wall thickness and you wanted to pick up a 1 inch hole in the wall. What is the best way to do this? Normally I would...
07-05-2017, 02:21 PM -
