I have a part with 24 equally spaced slots around an outer diameter. I could have used a pattern for this example, but I have other situations where a pattern would not work.
While the loop works just fine, what I was hoping for was that the the loop would perform the allignment rotation and all my dimension would report the true nominals and not adjust like what happens when you use a pattern.
example: the 15.22 dim in my code below is just a radius taken on a 30.44 diameter which is done 24 times around the part. I would like the nominal to report 15.22 for each point and not change. Can this be done?
I hope I wasnt too confusing with what I was trying to say.
V6 =LOOP/START, ID = YES, NUMBER = 24, START = 1, SKIP = ,
OFFSET: XAXIS = 0, YAXIS = 0, ZAXIS = 0, ANGLE = 15
PT18 =FEAT/POINT,RECT
THEO/15.305,-0.255,-0.12,0,1,0
ACTL/15.3052,-0.2589,-0.12,0,1,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,15.305,-0.255,-0.12,0,1,0,15.3052,-0.2589,-0.12,USE THEO = YES
ENDMEAS/
PT19 =FEAT/POINT,RECT
THEO/15.305,0.255,-0.12,0,-1,0
ACTL/15.3047,0.25,-0.12,0,-1,0
MEAS/POINT,1
HIT/BASIC,NORMAL,15.305,0.255,-0.12,0,-1,0,15.3047,0.25,-0.12,USE THEO = YES
ENDMEAS/
PT22 =FEAT/POINT,RECT
THEO/15.305,0,-0.12,0,0,1
ACTL/15.305,-0.0044,-0.12,0.000002,-0.0000008,1
CONSTR/POINT,MID,PT18,PT19
PT21 =FEAT/POINT,RECT
THEO/15.22,0,-0.12,1,0,0
ACTL/15.2169,0,-0.12,1,0,0
MEAS/POINT,1
HIT/BASIC,NORMAL,15.22,0,-0.12,1,0,0,15.2169,0,-0.12,USE THEO = YES
ENDMEAS/
DIM CHAR_76_5= TRUE POSITION OF POINT PT22 UNITS=IN ,$
GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER
AX MEAS NOMINAL +TOL -TOL BONUS DEV OUTTOL
X 15.3050 15.3050 0.0000
TP RFS 0.0100 0.0000 0.0001 0.0000 #--------
END OF DIMENSION CHAR_76_5
DIM DIST3= 2D DISTANCE FROM POINT PT18 TO POINT PT19 (CENTER TO CENTER), NO_RADIUS UNITS=IN ,$
M 0.5089 0.5100 0.0050 0.0050 -0.0011 0.0000 ---#-----
DIM CHAR_76_6= LOCATION OF POINT PT21 UNITS=IN ,$
X 15.2169 15.2200 0.0050 0.0050 -0.0031 0.0000 -#-------
END OF DIMENSION CHAR_76_6
LOOP/END
MEAS/POINT,1
MOVE/CLEARPLANE
ENDMEAS/
MEAS/POINT,1
ENDMEAS/
MEAS/POINT,1
ENDMEAS/
LOOP/END
