Form Editor Examples
  • Form Editor Examples
    Does anyone have an example of this that I can use to learn from.
    Robert Horne
    Va.
    There's a tutorial in the v4.x help files that should walk you through how to use the form editor create a form. See the "Creating Forms" topic under the "Reporting Measurement Results" section.
    Jared Hess - Techwriter @ WAI
    [View Reporting Tutorials Here]
      Hey Jared,
      Sort on the same note. Do you know how I can go about printing a form?
      I have tried the steps I would have taken in a hyper-report, that is...
      Open up the form editor
      Insert my .jpg (its a screen captureof the cad w/some labels turned on)
      insert a button control
      right click the button control and in the properties window go to eventclick, from there double click and choose C++ action|print|ok|save form
      At that point I insert the form into my program and run it, the form pops up, I have a button to click and when I click it it opens up the print dialog box I click print and it spits a blank page out at me.
        Sorry James. I get the same problem as you. Sounds like a bug to me. One thing you can do is set AUTOPRINT=PRINTER on the FORM/FILENAME command, and it'll send the form to the printer. But then you wouldn't be able to control it by clicking a button on the form...
        I tried coming up with a workaround where the form's Print button changes the text for a hidden text object named txtPrint to "TRUE" when clicked on and then closes the form, and then gives that value to a variable in the Edit window which when true would then print out the page.
        But this only sometimes actually prints. Most of the time it too spits out a blank page:
        SHOWFORM   =LABEL/
                    ASSIGN/BLN_PRINT="FALSE"
        CS1        =FORM/FILENAME= C:\PCDMIS42BETA\TESTPRINT.FORM, AUTOPRINT=NO
                    PARAM/TXTPRINT.TEXT=BLN_PRINT
                    PARAM/=
                    ENDFORM/
                    IF/BLN_PRINT=="TRUE"
        CS2        =FORM/FILENAME= C:\PCDMIS42BETA\TESTPRINT.FORM, AUTOPRINT=PRINTER
                    PARAM/=
                    ENDFORM/
                    GOTO/SHOWFORM
                    END_IF/
        I don't know.
          I was surprised this morning when the program I inserted the form into actually printed it as opposed to yesterday when it didn't. Hmmm
