247724 - The same point have diferent meas. results
248468 - I get an error indicating "CAD file could not be read. An attempt was made to access an unnamed file past
248860 - need to hook generic parser to ip measure, not ip planner its end.
248870 - SAVE/ALIGNMENT,ML_PCS,ML_PCS.ALN,MACHINETOPARTS is missing after the Import
248839 - Midplane construction produces undesired plane
248760 - Inch Units Operation hasa hugh Offsets
248728 - Regardless of new CCW option, starting and ending angles are getting made 0..360 which causes problems
248716 - AutoCircle/Cylinder BestFit Math Type not brought in from Legacy programs
248684 - The optimize path operation doesn’t flip the feature vectors - probe tip errors are the result
248678 - Can't pick points on the cloud
248652 - Path optimization sorts the features even when this option is switched off explicitly
248568 - DMIS dual arm pp doesn’t not import correctly. All commands are assigned to Arm1.
248557 - Change view in analyse Window object crash PC-DMIS
248544 - AutoVectorPt: Snap Problem as reported by James Mannes on user forum
248487 - Application is crashing when deleting commands
248479 - AutoRoundSlot's angle vector is being solved 90 degrees to what it should be.
248459 - Target folder for converted hyper reports
248446 - when I create a new FCF True Position in mm it shows the True position way out, again it looks like it's multiplying the mm dim. by 25.4 to come up with the location.
248419 - There are some unknown characters when I print the reporting to rtf file
248389 - AutoCircle: Studs with > 1 sample hits (with no avoidance moves): Errant circular move causing machine to drive off into space
248376 - Possible vector problem when RMeas feature has sample hits
248367 - AutoCircle - CCW CW combo is blank
248354 - pp with big amount of dimension failed
248292 - The PDF file doesn't show the correct dimension color
248262 - hyper report rpt files are distroyed after using the v4.2
248207 - ltvideo2.ocx needs to be included in the install set and registered in the application directory.
248097 - Error programs sfera85. prg resulted of the sphere non congruent
248042 - Always the whole CAD assembly is visible in the CAD images of the report window
247999 - PC-DMIS hangs when opening report window on large report
247981 - Lower tier of composite true position shows large deviations
247941 - When they convert their HRs to CRs the former variables and input comments parameters are not converted to the CR
247939 - After converting their hyper-reports to custom reports the part program executes 1min and 15 sec longer then before.
247928 - ‘Distance to closest CAD’ overrides ‘Distance to target’ during execution, making ‘Distance to target’ useless.
247920 - Convert a 3.7MR3 Hyperreport with Analysis Window to Customize Report doesn ´t work
247889 - Auto Feature: the master and Find Noms was confused ( Chinese and English are same)
247873 - AutoPlane - Laser - Target XYZ location changes when back saving to 4.1
247822 - Outside Cylinders using negative spacers and Avoidance Moves can cause the probe to crash
247637 - AutoEdgePt: with 0 sample hits on the hexblock. The depth is 2. When I execute the feature the hit is measured at a depth of 0.
247106 - Use CAD provided ID's for Feasture
246367 - AutoPlane: User-Defined Hits after we've moved the part, Avoidance movement doesn't work correctly
245116 - Point Clouds executed on Arm2 are not being drawn in the correct coordinates.
225154 - Selecting the feature TEXT from the CAD window does not select in the FCF.
247641 - After the alignment translation hits path is out of the Cad model
248107 - Measured results are modified each time I F9 on an FCF Position
248496 - AutoCylinder: Z value is incorporating Length in Dimension
249088 - Report Window ... for a productive use this is not usable.
249264 - Scans do not have Defined Execution Mode or Boundary Points
248561 - Print command will not print to PDF and report contains all zeros
249099 - App is crashing when converting a HR to a custom report
249137 - Crash when I try to convert a hyper to custom form
249140 - Can not close a report converted from a legacy report
249258 - The overwrite and append options forces an index onto the filename.
249237 - The form is always empty ,after i opened an exist form or create a new form
249337 - App is crashing when deleting CAD elements
248521 - They can't place fixtures with more than 12 columns
249037 - Auto-Sphere doesn't produce the correct diameter, when the hits are manually measured.
247817 - Autocircle Avoidance moves have fixed (large) distance
249106 - Measurement target area larger than FOV when measuring manual circle bigger than FOV - On Manual Machine
249142 - The reporting permanently causes the computers to hang
249377 - Bestfit with scan
249387 - Collision detection freezes half way through the process and hangs indefintely
249418 - PC-DMIS hangs when using a Dtype in the text expression field in the Edit Rule dialog
242529 - Angularity dimension for a plane displays unspecified projected tolerance zone in report label.
247955 - Auto insert moves is not working with Heidenhain probes
247571 - 2D Profile does not show hit targets after first click
248335 - Template reporting is screen resolution dependent and unusable for them therefore.
249300 - Serialization errors related to several scan features
249197 - T-Deviation is incorrect for features with ACTL thickness
249097 - FOV Cal focus range incorrect
249509 - Crash when reading optical calibration cert file
249444 - Probe Readout will not update on PC-DMIS startup without some help
249382 - The Measured Square slot in QS seems to be broken, it is very unpredictable
249361 - COP points are not deleted when the corresponding scan command is re-executed on arm2.
244029 - AutoLine: difficult to change length field in dialog
247301 - myhasp.dll needs to be copied to the perceptron directory to successfully load contour.dll
249171 - Problems when working with template ‘audi_a4_2a_pw.rtp’
249221 - Unable to perform perimeter scan on part
249265 - Status window display has changed - line is missing
249439 - Importing a CATPart causes PC-DMIS to Crash
249521 - Redraw the Report does not work correctly when template includes VARIABLE statement
245445 - Auto Focus in release build crashes
249553 - Clicking on targets in probe toolbox changes to the correct illumination, but clicking in the live view doesn't.
249557 - Section Cut profile is missing in the PDF file
241006 - Crash during Ring-Light calibration
245283 - Parfocality : with high calibration, for each step, the first focus use auto illumination, and not the other and the circle measurement
247184 - Unmarked Hyper-report commands are marked when reopening the pp.
248107 - The customizations on the tag items in the section cut settings dialog and the resulting image in the report window are out of sync
249639 - DoNotUse AmyuniRTF=1 causing color change in Report Window
249648 - Surface selection seems to be random in the UG DCI.
247260 - Old version of PCDShellextension.dll installed
248403 - Manual Laser scan, with multiple segments, looses data when done button is pressed
249550 - Mirrored part programs are not adjusting the AutoCircle Start/End Angles as expected causing machine crashes
249815 - Unable to register DLL: Dim Analysis Activex.ocx LoadLibrary failed.
240685 - DMIS imported AutoRoundSlot cannot be measured, bad THEO values
249615 - CurPage and NumPages are not working in reporting scripting language
249033 - Report Window does not update as dimension commands are executed
249712 - Multi-page report with Section Cut displays "No Image"
249724 - After pressing cancel in the dialog now a cut section object appears in the report.
249541 - Angle evaluation is incompatible with older versions - signs of evaluations change
249608 - When inserting text with audi_text.lbl the length is limited
249963 - VIEWSET functions were never properly implemented
243428 - Illumination set warning when using subroutine call
249715 - Progress bar during import of a STEP file
249894 - STEP imported models are not correct
I would say that it is a smaller list of FIXES than I have seen for some releases.
I like the very first one "247724 - The same point have diferent meas. results".
Makes you want to go right out and buy a second copy. I wounder if these "prototype" versions with the oopses in them will be collector items one day.
At least they are addressing the problems quicker than they used to. Look at how long 3.5 was out before the mr's showed up. And it still wasn't all fixed. That's my impression at least. I'm sure someone can cite and example of how I am wrong though.
