Ok, here's an interesting situation. I create a program that checks(amongst other things) a diameter. This diameter is supposed to be .7539 -.008. The tip calibrates fine. At the end of the program, the report says the diameter is over by at least anywhere between .003 and .0045. I check it with calipers and it measures (in metric) 19.15 or less--within tolerance. Can anyone see why it would do this?
Icky Diameters
Originally posted by operator1 View PostOk, here's an interesting situation. I create a program that checks(amongst other things) a diameter. This diameter is supposed to be .5739 -.008. The tip calibrates fine. At the end of the program, the report says the diameter is over by at least anywhere between .003 and .0045. I check it with calipers and it measures (in metric) 19.15 or less--within tolerance. Can anyone see why it would do this?
Are you using least sqr or max insc, min circsc & another thing is your tolerance on the diameter is only 8 microns. I would not use a cmm for this check. My .02sigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by bw_bob View PostAre you using least sqr or max insc, min circsc & another thing is your tolerance on the diameter is only 8 microns. I would not use a cmm for this check. My .02
I take 2 rows of hits, create a cylinder, and check the diameter of the 2 circles and the cylinder. When I create cylinders, it's always least square. Maybe I should try some other setup option? What is max-inscribe and minimum circsc?I feel a lot better now that I've lost my mind.
Global Activ
PCDMIS CAD ++3.5 MR2
None of those numbers work out right. 19.15mm = .7539"
19.15-.2 in metric = .7460"
19.15 (metric) (.7539") -.2" = .5539"
None of those options are even close to anything you posted for a size and tolerance.sigpic
Didn't work. The circles themselves are oversized. I take hits and create the feature, but the features are reported oversized. Both circles on both rows.I feel a lot better now that I've lost my mind.
Global Activ
You still need to give us correct numbers, your metric manually readins DO NOT match what you say anything should be, 19.15mm = .7539" OR more than 3/4 of an inch, your callout says 0.5739 or LESS than 9/16 of an inch. THese is a big size issue here OR faty-finger syndrome.sigpic
You sure? When I use conversion calculators, I get .5739. When I divide the inches by 25.4, I get .5739.
And for the .2 tolerance, I get .0078, or .008 in inches.I feel a lot better now that I've lost my mind.
Global Activ
Originally posted by operator1 View PostOk, here's an interesting situation. I create a program that checks(amongst other things) a diameter. This diameter is supposed to be .5739 -.008. The tip calibrates fine. At the end of the program, the report says the diameter is over by at least anywhere between .003 and .0045. I check it with calipers and it measures (in metric) 19.15 or less--within tolerance. Can anyone see why it would do this?sigpic
There is only a "minus" tolerance. The diameter can be no smaller than 18.95 and no bigger than 19.15.
In INCHES, the diameter can be no smaller than .5659 and no bigger than .5739I feel a lot better now that I've lost my mind.
Global Activ
Originally posted by operator1 View PostThere is only a "minus" tolerance. The diameter can be no smaller than 18.95 and no bigger than 19.15.
In INCHES, the diameter can be no smaller than .5659 and no bigger than .5739sigpic
Yeah. It's supposed to be .7539 or .7459, but the CMM measures circle 1--the first row--as
.7575, circle 2--the second row--as .7569, and the cylinder--constructed at least sqr, max insc OR min circsc--measures over.
Sorry about that. I'm on another planet right now.I feel a lot better now that I've lost my mind.
Global Activ
by khenryMy diameter measurements are not accurate. These are programs and fixtures that are verified to be reproducible and repeatable with a gage r&r. But...
04-13-2021, 09:57 AM -
Got something funny going on with my diameter measurements. I was wondering if someone could give me some insight. I am measuring a part thats outer diameter...
11-06-2014, 11:41 AM -
by #2#I have a question of all you masters...
I know some, if not most of you feel that a CMM is not good at measuring inside diameters. I have...-
09-28-2006, 11:22 AM -
I want to know what does "T&T INCL" on a diameter means?...
05-05-2020, 11:48 AM -
by NortonI have a diameter that is very slightly tapered but is square within CAD. From the top surface, I measure the diameter every 0.5mm measuring about 10...
Channel: PC-DMIS Code Samples
12-21-2016, 04:07 PM -
