Stay where I'm at or move on? This true postion crap in 3.7 is getting on my nerves. I can't use all my MMC without screwing everything up.
3.7mr3 vs. 4.2
Tags: None
Well, I can't say as I haven't used 4.2. I can say, however, that if you do decide to move on, do the following.
Copy all your programs and set up a directory structure for your existing programs. So, now you have two copies of all your programs. One set of programs can be converted up to 4.2 for trial purposes. The other set should remain unconverted. You should leave 3.7mr3 on the computer and that way, you can run those unconverted programs in 3.7mr3. You should do likewise with probe files as well but be aware that you will need to make sure you are looking in the correct directory for the correct version probe file.
Doing that will allow you to still check parts if for some reason the program that has been converted to 4.2 doesn't work. You will be able to run existing programs in 3.7 and fiddle around with 4.2 as you have time.
I worked with V4.2 last week while at a sister plant and liked what I saw. It took some getting used to the probe tool box and some of the pull downs have changed but over the look and feel was good. I am seriously think of upgrading our CMM to V4.2.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by WingmanAll,
I am trying this again. My plan for now is just to say NO to every question about converting. No conversion of programs. No conversion...-
06-28-2007, 10:18 AM -
by firehausAnybody heard on a release date for 4.2? The longer we are in 4.1, the more work arounds that have to be developed. If this keeps up much longer, thinking...
12-19-2006, 09:28 AM -
by DannyrlI must have done something wrong on the install although I think I followed Matts instructions correctly. The install seemed to go fine but i want to...
05-11-2007, 12:58 PM -
by John RigginsIf you are using Version 4.0, 4.1, or 4.2 and you had a choice to revert back to a previous version would you?
Why?Yes, if a New York minute.44.44%16No, I am happy with the newer version55.56%20-
08-10-2007, 06:08 PM -
by Paul SarrachMy new CMM is being installed as I type. It has 4.1 on it now.
Should I stick with that version or have the 4.2 installed?
Opions...
06-14-2007, 03:44 PM -
