3.7Mr3 Upgrade
  • 3.7Mr3 Upgrade
    Hey Yall, Ever since I upgraded to 3.7mr3 My move points have been changing or should I say the are not recording properly. The coordinates for the move points are off the map!!! When I type in the proper coords it ok!! I was wondering if any users have had this problem ? First time I have seen this thru any of the diff versions I have tried!! Any insight would be greatly appreciated.
    Haven't seen that myself. IS IT possible that you have IGNORE CAD=PART marked maybe?
      Are you using programs written in an older version? I have seen a lot of weird stuff with old programs coming into 3.7. In most cases deleting the problem and recreating the item, (feature, dim, movepoint, etc) will solve the problem. HTH (Hope This Helps)
        Are these movepoints in existing programs or new ones. I think you are saying when you insert a movepoint (ctrl+m, print button, or from the menu) they are inserting with unbelievable values. You then go back and edit them to what you want.
        Do those unbelievable values match what is in the probe readout window for position of the probe when you insert the movepoint?
          Thanks Matt Ignore cad=part was not checked. Good thought though!!
            New Programs I do the same with deleating and recreating features Mp etc.
              Yes that is what I am saying .Readout window was the first thing I checked. Move points in code did not match readout window .I verified readouts where correct. By placing tip over my 0,0 origin
                How unbelievable are the numbers? I am curious if it is using machine coordinates instead of current alignment coordinates for some reason.
                  Yeah at the time when it first happend I thought the same thing. It was not coming off machine coords because part was placed approx 8 inches in y from home pos y read 63 inches
                    Are you sure it is reporting inches and not mm? I wonder if there is a setting in F5 or somewhere that is causing your problems. If your SMA is current, then give them a call. It could be more of a hardware than a software problem.
                      I was wondering if someone was going to suggest that possibly it was reading in metric ? 63.000=2.4803 part was at least 8 inches from mach coords and no way was it 2.4803 from part in y it was about .150 SMA is current I will give em a call. I Like dealing with the cmm heads here on the forum. ( THE GUYS AND I BETTER INCLUDE GALS IN THE TRENCHES!!!) I will check settings and see if there is some sort of conflict going on!! Thanks for all ur help!!
                      • Robert Leach
                        3.7MR3 Issues
                        by Robert Leach
                        Hello, this board has been a great tool that I've used many times as a new user so thanks to all who post and answer questions We are having a issue...
                        04-06-2006, 07:53 AM
                      • DrBudman
                        Version Upgrade
                        by DrBudman
                        Was wondering if any of you could lend me a helping hand?
                        I'm going back to management to try to get my SMA approval to upgrade from my...
                        04-28-2006, 11:32 AM
                      • speedwagonfan
                        3.7MR1 to 3.7MR3
                        by speedwagonfan
                        The guys on first is quitting today and we are currently running 3.7MR1 and have MR2 and MR3 but are not installed. I want to upgrade to 3.7MR3 or...
                        06-02-2006, 04:26 AM
                      • Gary McElwain
                        Help with 3.7MR3
                        by Gary McElwain
                        I have been working on getting 3.7MR3 to work on a Sheffield RS50 since the first part of August. I have asked for help from B/S about the problems that...
                        11-06-2006, 10:09 AM
                      • spsayeski
                        Software versions
                        by spsayeski
                        We are currently running version 3.7MR3. We are looking to upgrade, but unsure which version we should upgrade to. Which version has the least amount...
                        10-30-2009, 03:17 PM
