I am getting this error now every time I run a program through offline.
What the %#(^%($*!!!!! And then the Demon crashes.
DIM LOC24= LOCATION OF POINT PNT5 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL PR 31.653 31.800 2.450 2.450 -0.147 0.000 ---#---- END OF DIMENSION LOC24 DIM LOC25= LOCATION OF POINT PNT6 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL PR 31.674 31.800 2.450 2.450 -0.126 0.000 ---#---- END OF DIMENSION LOC25 DIM LOC26= LOCATION OF POINT PNT7 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL PR 31.707 31.800 2.450 2.450 -0.093 0.000 ---#---- END OF DIMENSION LOC26 DIM LOC27= LOCATION OF POINT PNT8 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL PR 31.709 31.800 2.450 2.450 -0.091 0.000 ---#---- END OF DIMENSION LOC27 DIM LOC28= LOCATION OF POINT PNT9 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL PR 31.678 31.800 2.450 2.450 -0.122 0.000 ---#---- END OF DIMENSION LOC28 DIM LOC29= LOCATION OF POINT PNT10 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL PR 31.652 31.800 2.450 2.450 -0.148 0.000 ---#---- END OF DIMENSION LOC29 ASSIGN/V5 = LOC24.PR.MEAS-LOC29.PR.MEAS ASSIGN/V6 = LOC25.PR.MEAS-LOC28.PR.MEAS ASSIGN/V7 = LOC26.PR.MEAS-LOC27.PR.MEAS F1 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<ABS(V5),0.001,0>,$ MEAS/XYZ,<ABS(V5),0.001,-0.001>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1> F2 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<ABS(V6),-1451.6,-71>,$ MEAS/XYZ,<ABS(V6),-457.739,-981.05>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1> F3 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<ABS(V7),-1451.6,-71>,$ MEAS/XYZ,<ABS(V7),-457.74,-981.05>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1> $$ NO,Reference only for LOC101 DIM LOC31= LOCATION OF POINT F1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=NONE AX MEAS NOMINAL +TOL -TOL DEV OUTTOL X 0.001 0.000 1.000 0.000 0.001 0.000 #------- END OF DIMENSION LOC31 DIM LOC33= LOCATION OF POINT F2 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=NONE AX MEAS NOMINAL +TOL -TOL DEV OUTTOL X 0.005 0.000 1.000 0.000 0.005 0.000 #------- END OF DIMENSION LOC33 DIM LOC34= LOCATION OF POINT F3 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=NONE AX MEAS NOMINAL +TOL -TOL DEV OUTTOL X 0.003 0.000 1.000 0.000 0.003 0.000 #------- END OF DIMENSION LOC34 LN2 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<-50.8,-2.651,-31.689>,<0,-0.8869608,0.4618446> ACTL/<-50.8,-2.547,-31.607>,<0,-0.8869608,0.4618446> CONSTR/LINE,BF,3D,PNT8,PNT10,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 DIM LOC30= 3D DISTANCE FROM POINT PNT8 TO POINT PNT10, NO_RADIUS UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=NONE AX MEAS NOMINAL +TOL -TOL DEV OUTTOL M 24.530 24.530 0.010 0.010 0.000 0.000 ---#---- ASSIGN/V1 = LOC30.MEAS/2 ASSIGN/V2 = SQRT(31.8^2-V1^2) ALIGN2 =ALIGNMENT/START,RECALL:A4,LIST=YES ALIGNMENT/ROTATE,ZPLUS,TO,LN2,ABOUT,XPLUS ALIGNMENT/TRANS,ZAXIS,LN2 ALIGNMENT/TRANS,YAXIS,LN2 ALIGNMENT/END PNT39 =FEAT/POINT,CARTESIAN,NO THEO/<-50.8,29.379,0>,<0,0,1> ACTL/<-50.8,29.34,0>,<0,0,1> CONSTR/POINT,OFFSET,LN2,0,V2,0 LN3 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,-0.313,-11.49>,<0,0.0019749,0.999998> ACTL/<0,-0.313,-11.49>,<0,0.0019749,0.999998> CONSTR/LINE,BF,3D,PNT7,PNT5,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 DIM LOC101= 3D DISTANCE FROM POINT PNT7 TO POINT PNT5, NO_RADIUS UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=NONE AX MEAS NOMINAL +TOL -TOL DEV OUTTOL M 23.096 0.000 0.010 0.010 23.096 23.086 -------> ASSIGN/V3 = LOC101.MEAS/2 ASSIGN/V4 = SQRT(31.8^2-V3^2) ALIGN6 =ALIGNMENT/START,RECALL:ALIGN2,LIST=YES ALIGNMENT/ROTATE,ZPLUS,TO,LN3,ABOUT,XPLUS ALIGNMENT/TRANS,ZAXIS,LN3 ALIGNMENT/TRANS,YAXIS,LN3 ALIGNMENT/END PNT40 =FEAT/POINT,CARTESIAN,NO THEO/<0,29.693,0>,<0,0,1> ACTL/<0,29.629,0>,<0,0,1> CONSTR/POINT,OFFSET,LN3,0,V4,0 LN4 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<-50.8,29.669,0>,<0.9999999,0.000483,-0.0000036> ACTL/<-50.8,29.63,0>,<1,-0.0000104,-0.0000021> CONSTR/LINE,BF,3D,PNT39,PNT40,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 DIM LOC32= PERPENDICULARITY OF LINE LN4,RFS TO PLANE PLN3,RFS EXTENDLENGTH=0.000 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL M 0.001 0.000 1.000 0.000 0.001 0.000 #-------
