Move points with rotation
  • Move points with rotation
    Say I have a tip rotation in the code and a move point somewhere after that. I create a marked set which does not use the tip rotation. I'm seeing that the move point will rotate to this angle no matter what I do. Is this move point somehow referencing this tip angle? Has anyone else seen this issue?
    If the MOVEPOINT is after a tip change, then the tip change MUST be done for Pcdmis to move to that movepoint. Any feature after the tip change will also require the program to be at the tip. Anything after a tip will use that tip in the program, you can not 'skip' over a tip.
      I forgot to mention this is a move/all point. It moves to the correct tip but rotates to the previous tip first.
        Ah, you're screwed, that is something that Pcdmis does and it IS very annoying. Try putting in an extra move point, that might remove the problem.
