Is there anybody out there that has added an additional section to a standard V4.2 report template?
I was able to do that easily in off-line mode. Made some slick CAD views. It all looked promising. Was able to execute it in off-line mode. So I thought that I was all set.
Then when the code executed though NC, it keeps getting the dreaded pcdlrn run time error
. I keep getting this error until I eliminate the Section from the Report Template.
Very disappointing....
So my question is: has anybody tried this (adding a section to a standard RPT like TEXTONLY.RPT) and were you successful in on-line running this on your CMM? If so, then this may be an NC Server issue. Or is it a reported bug for all you 4heads out there?
Thanks, Jan.
Thanks, Jan.
