pattern question
  • Paul Sarrach
    Your program will runs all 8 parts correct? so each part should have it own Idenity say pnt1_1 pnt2_1 and so on. So copy paste the first set with the tolerance, then go to each new set change the name of the say pnt1_1 to pnt1_2 pnt2 to pnt2_2 and so on, part 8 will look like this pnt1_8 pnt2_2 and once you change the name of the feature the tolerance will change automaticlly the second number reflecting the part number
  • Kevin Watts
    started a topic pattern question
    pattern question
    hello. i am a new cmm user/ programmer. been at it about 3 months with no formal training. i am using a b&s global status.pc dmis cad 3.7 mr 1 i have learned a lot from this forum. my question is that i have a part that i have to make a pattern to check multiple parts. 8 at a time. i think i have the patern down good but i would like to know about inputing diminsions. do i have to diminsion each and every part or is there a way to copy the diminsioning to the pattern. so i can just program the dim for the first part and copy to the pattern. the parts have about 20close tolerance diminsions (+- .005" and +/-.001") that would be 160 seperate diminsions. it would be a big time saver to be able to do so. any help would be appreciated.
    Thanks
  • gage guru
    paste with pattern
    by gage guru
    Ok have 20 holes to measure and want to do paste with pattern. I understand how to do the paste with pattern and it works fine, but I want to make life...
    05-25-2006, 05:42 PM
  • TKOFaith
    Paste with Pattern
    by TKOFaith
    Hey all,
    Running 2013. Recently upgraded from v3.2063. I'm attempting to use Paste with Pattern at 45° 7 times on a round pot. PCDMIS...
    10-09-2013, 02:53 PM
  • PaulH129
    Pattern & Paste with Pattern
    by PaulH129
    I'm hoping someone here can help me......I'm running PC-DMIS 4.2 MR1....I'm trying to use the Paste with Pattern feature........I'm checking a part with...
    02-12-2008, 11:10 AM
  • d.evans
    Pattern question
    by d.evans
    I have a plate w/ a pattern of thru holes (.169"), which also have counter-bores (.300"). Is there a way to copy the pattern of thru holes,...
    06-25-2007, 12:05 PM
  • BANDY
    Selecting multiple features
    by BANDY
    I need to check 122 same dia holes on part and I wonder how do I select all of them and program this holes. Its kind of a pain doing it one-by-one.
    09-01-2006, 11:39 AM
