i m new to pcdmis. anybody can help me to check this slot profile? everytime i call out the profile, it shows only zero.
pls instruct me step by step.
[COLOR=#3366ff][CENTER][COLOR=#3366ff]Profile Form and Location of a Set using One Button Profile[/COLOR][/CENTER][/COLOR][CENTER][/CENTER] [COLOR=#3366ff] [LIST][*]Create a SET using a SCAN or by constructing one from points.[/LIST][LIST][*]Go to Edit/Preferences or hit F10 and turn on MAX/MIN in the Dimension tab.[/LIST][COLOR=green]FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS,;MEAS,NOM,TOL,DEV,OUTTOL,MAXMIN, [/COLOR] [LIST][*]Dimension the profile, Form and Location, turn OUTPUT to NONE[/LIST][COLOR=green]DIM LOC100= PROFILE OF SURFACE OF SET SET1 FORMANDLOCATION [/COLOR] [COLOR=green]GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=NONE[/COLOR] [COLOR=green]AX MEAS NOMINAL +TOL -TOL DEV OUTTOL MAX MIN [/COLOR] [COLOR=green]M 1.831 0.000 1.000 1.000 1.831 0.000 0.901 -0.930 #--[/COLOR] [LIST][*][COLOR=navy]Hit enter and type “AS” and hit Tab once. Change name to PROF1. Hit Tab once and type “[/COLOR][COLOR=#333399]LOC100.MAX”[/COLOR][COLOR=navy]. Repeat for PROF2.[/COLOR][/LIST][COLOR=green]ASSIGN/PROF1 = LOC100.MAX[/COLOR] [COLOR=green]ASSIGN/PROF2 = LOC100.MIN[/COLOR][LIST][*]Hit enter and type “GEN” and hit Tab once. Change name to SET1_MAX. Hit Tab once and F7 until feature changes to POINT. Change NOM X to PROF1 and MEAS X to PROF1. Repeat for SET1_MIN.[/LIST][COLOR=green]SET1_MAX =GENERIC/POINT,DEPENDENT,RECT,$[/COLOR] [COLOR=green] NOM/XYZ,PROF1,0,0,$[/COLOR] [COLOR=green] MEAS/XYZ,PROF1,0,0,$[/COLOR] [COLOR=green] NOM/IJK,0,0,1,$[/COLOR] [COLOR=green] MEAS/IJK,0,0,1[/COLOR] [COLOR=green]SET2_MIN =GENERIC/POINT,DEPENDENT,RECT,$[/COLOR] [COLOR=green] NOM/XYZ,PROF2,0,0,$[/COLOR] [COLOR=green] MEAS/XYZ,PROF2,0,0,$[/COLOR] [COLOR=green] NOM/IJK,0,0,1,$[/COLOR] [COLOR=green] MEAS/IJK,0,0,1[/COLOR] [LIST][*]Go to Edit/Preferences or hit F10 and turn off MAX/MIN in the Dimension tab.[/LIST][COLOR=green]FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS,;MEAS,NOM,TOL,DEV,OUTTOL, , [/COLOR] [LIST][*]Dimension the variable PROF_SET1 using DIMENSION/LOCATION in “X”.[/LIST][COLOR=green]DIM LOC1= LOCATION OF POINT SET1_MAX UNITS=MM ,$[/COLOR] [COLOR=green]GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH[/COLOR] [COLOR=green]AX MEAS NOMINAL +TOL -TOL DEV OUTTOL [/COLOR] [COLOR=green]X 0.901 0.000 1.000 0.000 0.901 0.000 --#[/COLOR] [COLOR=green]END OF DIMENSION LOC1[/COLOR] [COLOR=green]DIM LOC2= LOCATION OF POINT SET2_MIN UNITS=MM ,$[/COLOR] [COLOR=green]GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH[/COLOR] [COLOR=green]AX MEAS NOMINAL +TOL -TOL DEV OUTTOL [/COLOR] [COLOR=green]X -0.930 0.000 0.000 1.000 0.930 0.000 --#[/COLOR] [COLOR=green]END OF DIMENSION LOC2[/COLOR][LIST][*]Editing the XSTATS11.TMP file is not necessary.[/LIST][/COLOR]
