I anyone out there doing Stability studies on their CMM's?
Stability study
Same thing as running a master part weekly/monthly or a ball bar. I do it on the B&S training block and I know other do the same witht "master" parts.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by dwade View Postdump it into any stats progam and watch for variation.
Instead it will use the random numbers to tell both the operator and the CMM where on and or above the "RAYCO" plate the part is.
I have mine automated to the point now it is giving the operator instructions on where to place standoffs and after each run the program opens up a EXCEL sheet where I click on a button and the X,Y and Z are pulled into it. From there another sheet charts the info.
As my machine does not read temperature I do enter that manually.
We are looking at getting a second machine. My hope is that it will have TEMP COMP. and that I will be able some how to pull the temp right off the machine at the time of the run and have that added directly onto the chart also.
I have not heard much about TEMP COMP. does anyone know if this can be automatically output into a report? Or accessed for any external use?
by pgvsmitEverywhere I’ve worked we had a master part on a shelf in the gage lab. Except here…
We used it to double check the results from different...-
09-20-2022, 10:11 AM -
by WolfManHey guys, if you have a master part that is used to set the gage to zero or used for comparison relative to parts made, what kind of tolerance would the...
09-16-2019, 09:12 PM -
by acgarciaGood Morning,
I hate to add another master probe thread but I think this is a simple question which will get me a quick response.
07-24-2018, 12:00 PM -
How do you guys go about your master probe set ups? do you have a separate program that you bring in to locate the ball? I was told that a short robust...
11-12-2019, 09:09 AM -
by keegoI'm using 4 different SP25 modules and tip configurations in a program. Does it matter which one I make the master, i.e. the one when I calibrate I say...
01-06-2010, 09:59 AM -
