I am running 3.207 on two of my CMM's and 4.1 on the other... The question I have is this, is there an easy way of getting my data to an AIAG dimnensional sheet? any help would be appreciated.
4.1 has a template for that, but IMNSHO it's not the greatest. Usually I will send the data to DataPage and import the .txt into Excel. I am assuming that the dimensional form that you are using is in Excel. This will work regardless of which version of PC-DMIS you are using.
EHines... you are correct, it's in excel, and I do send it to DataPage, but the parts we are PPAPing have about 9 sheets worht of data... alot of cutting and pasting and typing just trying to get a work around, but thanks!
Can you create a macro in excel to do these repetitive tasks for you?
It's called cmmautoimport.zip, please download file from there, as no more emails will be sent out. I would however appreciate feedback from all those who take a look: james<[{at}]>dptool.com
I've seen the thread on how to convert Datapage to Excel. Is this something that has to be manually done each time you want to convert a Spreadsheet...
