I did that a long time ago. It should tell you on your print how far out of the hole or whatever it is, your reference length of this cylinder should be. If it doesn't then default to the length of your cylinder check. Also, the print should tell you how it needs to be checked, such as axial average, etc. If it doesn't , default to axis average.
I have a customer that wants to know if the true position of a cylinder only measures the location of the cylinder or does it take the perpendicularity...
I know true position has been discussed before. But I still don't quite get it after reading these discussion. When I tried to find the true position...
So I'm using PCDMIS 2020 R1, I have a 2 cylinders that have true position and perp. call outs. This seem redundant because the primary dat is the same...
This is what I have. I'm not seeing this happening. I have two rotations, which is no problem. Just don't have any basics after that. And I've never TP'd...
