We're having another problem with the cmm here. The program runs a 1x20 probe just fine but when it switches to the smaller probe its all screwed up. I put in an alignment for the small probe and it runs that fine but when I do an auto feature for a hole the thing goes to the other side of the table!!!!! My boss said he had a problem simular to this before and he had to delete a dll(?) or ini file by going in thru explorer.... anyone have any ideas? thanks
1x20 probe works mint......... .3x10 not so much! help!
Before you go deleting anything...
Try re-calibrating both probes to make sure they are properly related.
Try a complete shutdown and re-boot.
I'd venture that if either of those doesn't fix it, there is something hiding in the program somewhere that is screwing it up.
Post some code of the probe switch and the features in question. I am almost certain it's an alignment or code issue.I used to be high on life but I built up a tolerance.
Originally posted by chainfeed View PostWe're having another problem with the cmm here. The program runs a 1x20 probe just fine but when it switches to the smaller probe its all screwed up. I put in an alignment for the small probe and it runs that fine but when I do an auto feature for a hole the thing goes to the other side of the table!!!!! My boss said he had a problem simular to this before and he had to delete a dll(?) or ini file by going in thru explorer.... anyone have any ideas? thanks
What are you trying to do. Do you need a different probe in the program. Are you using a tp20 or tp 200. A little more info please....sigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by slesholdofthreep View PostSo you are saying that you have captured features w/ the 3x10, do an alignment and then the probe takes off?
Originally posted by chainfeed View Postyah thats what it was it was doing... I deleted the part of the program that used to the second probe and started over again,,,, so far it seems to be working alright.sigpic
Originally posted by AJHVW93 View PostI did the same thing when I has this problem. Deleting that part of the program was a temporary fix. MEANING IT WOULD RUN ONCE JUST FINE! RAN THE PROGRAM AGAIN AND OFF IT WENT. Run your program several times!!!
by B. JacobsI am about ot delete all probe files. I believe one or more of them are corupt. I have copied the probe files, probe results to another folder elsewhere....
08-07-2009, 11:42 AM -
by D-TrainHey guys and gals, without having that much time to go through every thread out there and check, can someone point me in the direction of where to go...
11-04-2015, 05:26 PM -
by caryweaverWe have recently had an issue of a bad or corrupt probe file causing serious measurement error, as much as 0.040". After deleting the probe and...
08-05-2014, 05:04 PM -
by tinabethUsing 4.1 PCDMIS with a tp200 with magnetic modular.
I'm trying to understand more about changing probes in programs?
I have probe files...-
10-11-2009, 05:44 PM -
by John KuglerLate last week we had a probe go corrupt. 2nd shift guy was running a program that we had run MANY times in the past. Program went and picked up the...
06-19-2006, 09:59 AM -
