Hello All
I am trying to measure a hole that is at a compound angle to the alignment. There are no surfaces perendicular or parallel to this hole and I do not know the angle it is at. If the part were a cube the hole would be at a random angle starting from the intersect of 2 edges and going out one of the others. It is also intersected by three other holes that are also at a random angle. I have tried to make a circle to get the vectors but everything i tried results in vectors that are not even close to correct. The proble angle I'm using is close enough to measure the hole but clearly not perfect. By the way there are 30 more holes like this on the part that I need to measure as well.
Any ideas on how to pick these?
PC-DMIS 3.5 MR1
PH10M
TP20
Sharpe 32 controller
Thanks
PC-DMIS 3.5 MR1
PH10M
TP20
Thanks
