I was reading an old thread about readpoints and was alittle confused. Could someone provide a "really" simple example of how I could use readpoints to simplify the measurement process (alignments etc).
Thanks
I just learned about these this morning. See if this helps you.
I use them at the beginning of a program to ensure that no matter where the operator manually leaves the probe in relation to the part it will not crash. I put in a readpoint right after the dcc command. Then, I put in a move point that references the readpoint's location.
So, for example if I start out with angle A0B0 I put in the readpoint (pnt1) and then the movepoint (move/point pnt1.x,pnt1.y,10). That causes the probe to move up 10 in z no matter where it is located.
It works kind of like a clearplane before the first dcc feature without using a clearplane.
In the example you have provided, a MOVE/INCREMENT is what you are achieving.
The only time i use readpoints is at the beginning of programs. I place the probe were desired & the correct probe angle. I do a readpoint set it at my xyz orgin. I then go to dcc and continue setting up the alignment. Does away with manual hits.........love it
That would be true and it doesn't move to pnt .x and .y of your readpoint.
Oh, so a move/increment if I put it in as 0,0,1 is going to move up 1 inch no matter where it started. If I put in the readpoint, etc it will move up to 1 inch above the z-orgin. So, can I put in a move/increment as 0,0,whatever the z orgin is set to .z+1 to get it to move 1 inch above the z-orgin?
I wish it would let you move just one axis at a time.
I just tried a move/increment with 0,0,pnt1.z+.2 and it only moves .2 in z no matter where the probe is located.
So, I think I will stick with the readpoint & movepoint routine. That way no matter where the probe is left I can have it move straight up in Z and not in x or y until it is a set distance above the z orgin.
I made a program and finally I took move increment (0,0,85) in MM. The CMM probe had enough space to go up so I took another move increment (0,0,50)...
When I input a move point relearn, and it comes up in the program to move probe to the new location and hit ok......I can't move my machine. It's like...
