This usually doesn't happen. I've opened and closed programs after several days and the CAD display is always there- did I say always- oops- I mean usually. The program still seems to run ok. I'd like to see the CAD surfaces to do auto features by clicking on the CAD surfaces when
I'm adding measurements to the program.
Anybody know whatzup?
THANKS ALL
Mike
"listening for the last trump... looking toward the eastern sky"
Sometimes, depending on version (3.7MR3), the CAD just simply isn't displayed. Try hitting the FIT TO SCREEN icon and see if it won't redraw and come back.
I have had this happen when I am merging to cad files and do not create layers for each of the cad models under view setup. The cad file would show in the same directory as program but would not show up on screen until I exited the program and then restarted program.
Yea, I'm definitely behind the curve with this folder-directory,etc. stuff.
I know that the .prg and .cad files are both in the pcdmisw whatzit. Though
they are seperated by a few other programs- do the need to be in the same spot- you know the .cad following the correct .prg ??
MJB
The above posts are correct.
(At least in 2013 MR1!)
But I don't see enough of "This is the right answer!" replies on these forums, so here ya go!
I had a .CAD and corresponding .PRG. I had one revision, File>Saved As a new revision, and finished the program.
I had two of the "same" program so I deleted the dummy original file and renamed the new file what the old file was, for posterity's sake.
(When I make a new program to test out some code for an old program, I name it something like "XXXXX - THISISATEST.PRG")
Thus it was like I never had a dummy program to begin with...
But after I opened up the program to run it, the CAD was gone!
I was under the impression it just wasn't drawing it or something; I know how finicky PC-DMIS can be.
I consulted the interwebs, and finally fell upon this post.
I saw I had a .CAD file that had the old name, and some other files (.PRG^, etc) that had the old (new old?) "THISISATEST" name, AND they were in the original PC-DMIS search path!
(I have folders for each part inside the search path, the files were just outside of these directories, e.g. not in the same folder as the program)
Once I renamed the .CAD to the updated revision (with PC-DMIS closed) I was able to see the model again.
I have a program that I've run a few times recently, and when I open it this time the cad is missing from the display window. Not sure why this happened,...
So, Im in this program and I'm trying to bring up the Cad Model within the graphics window. The only problem is that I can't access Cad levels to insert...
I have a family of parts that I programmed and used my template program. The first program I wrote, I imported the CAD and saved (CTRL + S) the program...
