I have built a star probe using 3mmx10mm tips. I have a dual sphere qualification tool. I am using all 5 tips in the A0B0 position only. I select the tips and send it off to calibrate DCC. Tip # 3 must calibrate on the bottom sphere, whereas the other 4 use the upper sphere. I did not create the artifact and the help menus are no use, but the software seems to know I have two spheres and where they are located as it goes to the bottom sphere for #3. BUT when I call up Tip #3 to use it in the program the demon thinks it is in a different place from where it really is by the difference in the actual location of the two spheres.
Any help would be greatly appreciated.
