Can someone please tell me where the approach setting for the probe rack can be adjusted? This is our first rack and we can get the probes to change alright but I have to leave the cover open for the stylus with the four way on it because the side probes will hit it when switching to and from that sensor. I'm guessing there has to be a setting somewhere to adjust the approach to and retract from the rack. Or my second guess is that this is somehow determined from the definition of the probe. The side probes calibrate and measure fine so I'm hoping it is not the definition of the probe - however I did have to define the side probes in the probe.dat file myself because it was not one of the pre-programmed choices in the drop down list - so there could be something in that code that I do not understand correctly that could be causing this to happen.
